ac turns off at idle
Anyway, just go to autozone and buy the 134a that comes with a gauge, $16 last time I bought one. Its an idiot gauge, but it works. Or go to a local shop, they will check your charge for pretty cheap. Some of the local places here will check and charge the system for like $40 up to 2 lbs.
If you pick up a bottle of freon, you'll notice it feels like there's a liquid inside, which there is. You can pump freon into a 1/2 full bottle for 10 minutes, let it sit, then check the pressure. It will be exactly the same regardless of it being 3/4 full or 7/8th full. Inside the bottle, the freon is at a saturated liquid/vapor state.
Instead of increasing in pressure, the gas condenses to a liquid given the right temperature.
Yes I do have a T&P chart and I am also EPA609 Certified and have a whole lot of paperwork on A/C and if all thats wrong then damn you guys are pretty good but I highly doubt thats all wrong. But my bad I was so wrong. Peace
And BTW, I'm epa certified as well, and nate certified.
mabye the pressure change is verry little in the can but its there..its phsyics
At a certain point yes the pressure can come down if volume comes down. But thats when the volume is very low for a certain size container. I buy refrigerant in 30 lb jugs. I promise you that if I have 3 cans, lets say one has 10 lbs, one has 20 lbs, and one has 30 lbs, they will all read the same pressure if they are the same temperature. Now if I have maybe 1 lb or less in a can the pressure can be less than it should be, but thats extreme. In this situation, of this guys A/C system was low enough on charge to read low pressure at ambient then his A/C wouldn't even come close to working, and he says it works at least sometimes. So it was a bad suggestion regardless, especially from someone who supposedly knows what he is doing.
Have you gotten any guages or anything yet and hooked them up to your car? If so what kind of pressures are you getting?
The pressure will be the same in the system wether there is 1lb of freon or 10lbs of freon.
I agree if you hook up the guages while the car isn't running and get 30psi, you've got problems, this means there's not enough in the system. You can pump freon in and it will hit a certain pressure then the pressure will stop climbing. From here on out, you're going to stack liquid in the system untill it is full as if you were putting water in a bottle.
P=Pressure
V=Volume
T=temperature
n and r are constants and I don't remember their values as they change for different gasses if I am not mistaken.
If Pressure or Volume increase then Temperature has to increase as well to keep the equation balanced. So if Temperature increases and Volume is fixed then the Pressure will increase.
P=Pressure
V=Volume
T=temperature
