View Poll Results: My factory alternator for my LS1 died between
Voters: 122. You may not vote on this poll
LS1 owners: how miles did your factory alternator last?
#41
A weak battery will be a lot harder on the alternator, and since most people don't replace batteries until they are 100% toast, it is part of the equation. If you can only run your acc for 10 minutes on your battery, it's time for a new one.
About replacements, remanufactured alternators are a total crap shoot for some reason I've never understood. Pretty much the only good thing is that if you get a bad one, it'll die fast.
#53
I lost my alternator on the formula with about 6,000 miles. Got it replaced under warranty and haven't had a problem since. In fact its the only problem I've ever had with the formula.
#54
155,000 MIles on my 2000 Z28...stock everything related to electrical stuff.
The only issue I have had is with my Alt Gauge and the interior lights. The gauge wiggles a bit (not much at all, but it wiggles) and the lights only on start up seem to pulse somewhat...but at Kragen they did a live load test of electrical and found it to be fine...so I shall drive it till it erupts..then go to a special rebuild shop and have it rebuilt..155k so far..how many more one will have to wait and see
#56
47000 on the stock but my lights flicker during startup and then the just continue flickering after start up and im debating on if i should change my alt or not to see if the flickering stops.
#57
Originally Posted by Hawk108
47000 on the stock but my lights flicker during startup and then the just continue flickering during start up and im debating on if i should change my alt or not to see if the flickering stops.
Keep me posted on the flickering and pulsing lights, i have the same problem.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
#58
