dropping the motor with out a lift???
Old Jun 18, 2006 | 05:58 PM
30th t/a's Avatar
Default dropping the motor with out a lift???
anybody want to share on how they dropped their motor from underneath without a lift? or if anyone knows where to find step by step instructions on dropping the motor without a lift, id appreciate it.
Old Jun 18, 2006 | 06:08 PM
davered00ss's Avatar
Moderator
Pull it from the top. You can use an engine hoist (cherry picker) and lift the nose of the car with that.
Old Jun 18, 2006 | 06:16 PM
Mike02Z's Avatar
Wow Dave that has got to be a bitch with how far back the engine sits. Have you actually pulled one from the top before? Just curious as I was looking at mine the other day and it looks brutal to get from the top.
Old Jun 18, 2006 | 06:20 PM
DocEwww's Avatar
I pulled mine from the top w/ jackstands...I took the trans out first tho.
Took me a few hours, wasnt bad at all. Much easier than my 4wd Toyota truck
Old Jun 18, 2006 | 06:25 PM
Moderator
You need to take the nose off to get the cherry picker close enough.
LS2 402
Old Jun 18, 2006 | 06:32 PM
shanev8's Avatar
is there a guide to this??? any other lil tricks
Old Jun 18, 2006 | 06:34 PM
Moderator
Luckily we had a friend that has done litterly dozens of motor swaps on F-bodies and vette's to help out.
Old Jun 18, 2006 | 06:36 PM
shanev8's Avatar
is there a install guide, i know there is one but i just cant remember where i saw it at.....
Old Jun 18, 2006 | 06:38 PM
30th t/a's Avatar
cant pull it from the top. turbo manifolds wont allow that. and the time it would take to remove the manifolds i could have it out from the bottom.
Old Jun 18, 2006 | 06:41 PM
Moderator
We pulled the exhaust first.
Old Jun 18, 2006 | 06:42 PM
Moderator
I don't know about a guide, but it was not hard at all.
Old Jun 18, 2006 | 06:57 PM
shanev8's Avatar
what about installing the new motor?
also it can be done with a long block (heads still on)?
Old Jun 18, 2006 | 07:00 PM
camaroextra's Avatar
Iv used a forlift to lift the front of the car up over the engine.
Old Jun 18, 2006 | 10:13 PM
SVC707's Avatar
what would you mount the chains to on a long block, heads attached. im trying to figure out how im going to put my new motor in trans is still in the car but my motors sits fully assembled. when i pulled it out there were no heads so i put the chains to the head bolts.. where do i now?
Old Jun 19, 2006 | 01:19 AM
1BADAIR's Avatar
Have done a few like this
Old Jun 19, 2006 | 07:56 AM
Hodge's Avatar
To pull the engine out of a C5, look at the pics on my web site: http://www.hodge-rulez.com/
Old Jun 19, 2006 | 09:56 AM
DuronClocker's Avatar
That's how I did mine. I thought it was really fairly easy. Didn't take more than a couple hours..
