Is the coolant line from the radiator to the TB line really needed?
Old Apr 9, 2003 | 01:57 PM
Magnus's Avatar
LS1TECH Sponsor
Default Is the coolant line from the radiator to the TB line really needed?
Many of us do TB coolant bypasses, but is that coolant line really needed? What would happen if I were to just plug up each end and ditch the line all together?
- Keith
Old Apr 9, 2003 | 02:34 PM
CMNTMXR57's Avatar
Default Re: Is the coolant line from the radiator to the TB line really needed?
No, that's one of the "free" mods on our cars. It's only a concern if you're concerned about the TB getting "iced" from moist, cold air.
<small>[ April 09, 2003, 02:36 PM: Message edited by: CMNTMXR57 ]</small>
Old Apr 9, 2003 | 02:38 PM
Magnus's Avatar
LS1TECH Sponsor
I'm not talking about bypassing the TB... but removing the coolant line all together and plugging up the connection on the radiator and that rail tha goes between the heads.
Old Apr 9, 2003 | 11:30 PM
CMNTMXR57's Avatar
I'm sure you could and it won't hurt a thing but I wouldn't! I'd just spend the $.50 I did at True Value, pick up a plastic connector and bypass it. Simple as that. Everything is still operational, it just doesn't flow through the TB.
What do you wish to accomplish by plugging it at the radiator?
Old Apr 10, 2003 | 02:18 AM
Venkman's Avatar
i just made it a single hose from the radiator to the block. Cost me about $.75 in hose.
Old Apr 10, 2003 | 08:41 AM
Magnus's Avatar
LS1TECH Sponsor
The line comes off the coolant line that goes inbetween the heads underneat the intake.
I ask this because I'm doing an engine swap, putting an LS1 into a 97 f-body and wonder if I just don't bother with it, will cooling be affected.
Old Apr 10, 2003 | 09:18 AM
Murdock's Avatar
That line is the air bleed from the engine to the radiator. If you remove it, the engine might not purge the air after the coolant refill.
Old Apr 10, 2003 | 09:24 AM
Tin Indian's Avatar
Those are basically steam lines. I would not block them altogather
You can, however, purchase the LS6 coolant pipe. That illiminates the rear coolant lines. That way, no coolant lines will be under the intake. You will need the plugs to cap off the holes in the rear cyl heads that the original coolant lines hooked to. Still will retain the front coolant lines to each head that join and go to the top of the radiator.
Ron,
Old Apr 14, 2003 | 10:14 AM
Magnus's Avatar
LS1TECH Sponsor
What's the difference between the LS6 coolant pipe and the LS1?
I'm just trying to make this as clean as possible. Perhaps I'll install a bleeder valve on the front coolant line to manually bleed it after a coolant change.
Old Apr 14, 2003 | 01:29 PM
Steve1969LS1's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Magnus:
<strong> 97 with a 99 LS1 motor. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I understand how the pipes work. Thanks.
I may just run a coolant hose around a long way from the front pipe to the radiator to keep it clean, we'll see. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I wondered the same thing.. in the end I just had an #6 an fitting welded on the LS6 coolant line an ran braid to the radiator.. Id rather not have it there but at least now it looks good <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<img src="http://members.aol.com/steven0932/bypass.jpg" alt=" - " />
Old Apr 14, 2003 | 01:38 PM
Magnus's Avatar
LS1TECH Sponsor
Hey Steve, I saw your pics before. The engine bay looks VERY clean.
Thanks for the reply. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Apr 14, 2003 | 01:53 PM
CMNTMXR57's Avatar
I don't know about you, but I don't see any braided lines there in that pic with all that chrome and shine. <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" />
I think my Bling-O-Meter just overheated! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<small>[ April 14, 2003, 01:54 PM: Message edited by: CMNTMXR57 ]</small>
Old Apr 15, 2003 | 12:26 AM
Murdock's Avatar
Magnus: The LS1 pipe has 4 pick-ups. One at the front of each head, and one at the back of each head. The rear pick-ups merge and then run under the center of the intake to merge with the front pick-ups. The LS6 pipe only has the 2 front pickups. If you get an LS6 intake you have to switch to the LS6 pipes, since there's no room for the LS1 pipes to run underneath the LS6 intake.
What year's your car? If 2001 or 2002 you already have the LS6 pipes.
Old Apr 15, 2003 | 12:40 AM
Magnus's Avatar
LS1TECH Sponsor
Old Apr 15, 2003 | 03:04 PM
Fenris Ulf's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Murdock:
<strong> That line is the air bleed from the engine to the radiator. If you remove it, the engine might not purge the air after the coolant refill. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Very true, I definately would not do it. Steam pockets can be very destructive unchecked.
Old Apr 15, 2003 | 03:28 PM
Tin Indian's Avatar
I'm about ready to just ship my car to the Philippines. Pay 2 or 3 guys $1.25 per hour to polish until there arms fall off.
I figure in about a week or two, I may be able to out-bling Steve. But, then again, maybe not... <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Ron,
