Loudmouth Disaster - RASP
Re: Loudmouth Disaster - RASP
I am curious....what kind of cats are you using and how much rasp do you have? I beleive that cats are suppose to kill most of the rasp?
I am using High Flow SLP cats to go along with the SLP headers.
Borla makes a resonator type to put in place of the loudmouth? or did you mean add one to this system in the rear?
If I add in the rear, it would only be for the driver side since the passenger exit tube comes straight out.
Thanks
VinMan
Thanks
VinMan
Its a borla bullet race style muffler. you put it in the place of the resonator <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
If it is just a little rasp and a small amount of noise reduction you want, a dynomax 3" race bullet will do the trick and not hurt power. Its only $50 or less. The 18" (24" overall) probably will fit where the resonator is.
For more sound control the Borla XR-1s or non-race straight through round mufflers will do the job.
If you're going to do the dynomax in place of the resonator thing... don't get your hopes up, it only helps a little. I got so tired of the NASCAR sound that I went true dual... LOUDMOUTH SUCKS WITH HEADERS!!!!
Fella's,
I have SLP Lt's, High Flow cats and installed the Loudmouth. I bought the loudmouth a long time ago, at that time I wasn't considering headers. I HATE the rasp and the sound.
this started becasue I had a bent PR and then I decided last minute to put in a new TR224 @ 112 cam along with Headers....
I had to have some custom welds and brackets to make the exhaust fit correctly so I'm too far into this loudmouth, I don't want to "Punt" and get a new exhaust, I'm hoping to fix it by installing some other mufflers in the system....
By the way, the SLP headers hang pretty low and the cats come off at a slight negative angle. Just FYI for anyone thinking of getting them.
Any suggestions on how to rid the RASP and still use the existinig pipes which are welded-in?
Thanks
VinMan
Thanks
VinMan
Heres the link. Its a borlamouth with mac headers and offroad pipes.
http://www.jupiterdentist.com/z28/movies/borlaslp.mpg
Enjoy!
http://www.jupiterdentist.com/z28/images/borlaslp/
This link will explain the install. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
<small>[ April 11, 2003, 12:18 PM: Message edited by: dug ]</small>
Enjoy!
I'm going to try a Bullett in place of the current resonator.
Just FYI... I don't hate the sound as much as I did the other day, but I still don't like it.
After the installation I'll post a new sound response and let you guys know how it sounds.
Thanks for the help.
VinMan Out....
VinMan Out....
