Pro’s and cons of stainless exhaust
Stainless vs. mild steel:
Stainless is more expensive.
Stainless looks nicer.
Stainless headers add more heat to the engine bay, compared to ceramic coated mild steel.
Stainless resists rust better; will last longer.
Stainless steel is more temperature-sensitive to embrittlement; less flexible.
If I am missing anything, please feel free to comment. Thanks.
I'm just curious, but what did the performance shop say to make you re-evaluate your choice of going with stainless steel? Was it b/c stainless is more expensive? If so, that should be the only reason why you should choose mild steel over stainless IMO. I wouldn't get the mild steel unless you are on a very tight budget and just want LTs now. Going stainless is a wise investment especially if you plan on keeping your car for a long time.
Mild steel is pretty crappy and will likely rust fairly quick. Low milage cars are often far worse, as there are few things worse for a car than just sitting doing nothing. Water will be inside the exhaust as much as outside.
Some claim bad things about stainlees steel but I've only ever seen it from people who don't have a stainlees steel setup and are trying to justify it.
If you don't think you'll keep the car long then get mild steel. 12 months to 3 years is a sensible time to expect it to last.
If the car is for keeps get stainlees and don't worry about replacing it.
I'm about to have stainless headers into a mild steel y-pipe into a stainless catback.
" RETARTED "
.............[ RETARDED ]
Buy a stainless kit yourself and get someone to install it for you. I have American Racing headers, cats, and y-pipe. Previous to that was coated Jet Hots which looked like complete crap after two years never being driven in rain or snow. What a waste of money.
Get stainless.
Get stainless.
Buy anyway, stainless all the way, does Kooks use anything but stainless? Tells you something right there
