Working on the Hawk as WE SPEAK...
Old Jul 6, 2006 | 04:27 PM
DBeck's Avatar
Default Working on the Hawk as WE SPEAK...
and I cant get the damn battery out. How do i get the stock battery out, so i can put in my optima???
PLEASE HELP
Old Jul 6, 2006 | 04:28 PM
Phlip00WS6's Avatar
You have to unbolt the plastic thing at the bottom.. it holds on the to batter. Youll need a big extension. Its facing the rear of the car.
Old Jul 6, 2006 | 04:31 PM
DBeck's Avatar
so that first? what about the black and red clamps?
Old Jul 6, 2006 | 04:35 PM
Phlip00WS6's Avatar
yes, you have to remove the battery terminals, do that first then the clamp at the bottom.
Old Jul 6, 2006 | 04:49 PM
DBeck's Avatar
and those just pop off correct?
Old Jul 6, 2006 | 04:57 PM
Phlip00WS6's Avatar
The terminals are held on the side by a bolt thats in the center of them.
Old Jul 6, 2006 | 04:58 PM
DBeck's Avatar
alright, cause i started by tryin to pop off the rubber pieces with a screwdriver... hope i didnt f anything up..
Old Jul 6, 2006 | 05:00 PM
NassyVette's Avatar
Be careful when you tighten them back into the battery, they strip easily.
Old Jul 6, 2006 | 05:05 PM
BIG_MIKE2005's Avatar
ok, I wouldn't work on my car alone if I couldn't figure out how to get my own battery out. Thats kinda a bad sign of lack of mechanical knowledge. Just make sure you don't mess anything else up while your at it.
Good luck
Old Jul 6, 2006 | 05:13 PM
00transamnh's Avatar
Baaaaaaaaaaaaaaaaaaaaahahahahahahaahahahahah
Old Jul 6, 2006 | 05:16 PM
DBeck's Avatar
yea, one of them was previously stripped, and now, i dunno how the hell to get it off
Old Jul 6, 2006 | 05:17 PM
DBeck's Avatar
Good luck
gotta learn mechanical knowledge somehow...
Phlip00WS6's Avatar
Get a pair of channel locks and grab the bolt real tight so it doesnt strip even more and it will come off.
Old Jul 6, 2006 | 05:20 PM
DBeck's Avatar
alright
DBeck's Avatar
alright, thanks
Old Jul 6, 2006 | 05:37 PM
THE CHOP SHOP's Avatar
Be careful when you put the new battery in and pull the old one out. The other tab that stays stationary can break. Whoever did the last battey swap on my car broke it and you have to replace the whole over flow container to fix it.
DBeck's Avatar
k, the thing is shot, completely stripped. what the hell do i do now?
Old Jul 6, 2006 | 05:39 PM
DBeck's Avatar
what tab are you talking about?
Old Jul 6, 2006 | 05:53 PM
blkbird's Avatar
Is it the positive or negative battery cable that is stripped?
Old Jul 6, 2006 | 06:11 PM
DBeck's Avatar
red, so positive. it was stripped to hell, but i used a vice wrench on it and got it off. the thing is so corroded. Now what will need to be replaced... can i just replace that bolt?
