Ebay catch can
Old Jul 11, 2006 | 06:11 PM
black2002ws6's Avatar
Default Ebay catch can
Got this off ebay.
Old Jul 11, 2006 | 06:42 PM
radz282003's Avatar
Not the same one, but that' s where I got mine. Couldn' t see spending a $100. It works pretty good, too.
Old Jul 13, 2006 | 10:59 AM
Runn's Avatar
Nice one... can i get a link
Old Jul 13, 2006 | 12:44 PM
99kamarokid's Avatar
http://cgi.ebay.com/ebaymotors/OIL-C...QQcmdZViewItem
heres the one i saw, but i didnt know if it would work..
Old Jul 13, 2006 | 04:45 PM
BobbyWS6's Avatar
just a question, not tying to say anything bad because you have put a lot of time and work into your engine bay. But should the Can be at the shortest distance possible from the engine/ throttle body? I would think that your set-up might fill your line from the engine to the Can quicker than some of the others I've seen mounted on the passenger side of the car? By that I mean oil is heavy and may coat the side of the hose. Anyway, I dont have a Oil catch can yet, but I will soom and how long have you had yours on your car and do you get a lot or a little out of your can. Also, Have you taken the hose off and checked the amount of oil dripping out of the lines?? Anyway, your engine bay looks awesome. Even if you chose purple...
Old Jul 13, 2006 | 06:16 PM
Country Boy's Avatar
Senior Member
That engine bay is HOT!
I wouldnt see the distance being a problem as its still in the system and has to go through it no matter how long the hose is.
Old Jul 13, 2006 | 07:05 PM
dummer's Avatar
Looks good, but one question:
How do you drain the oil from it when it's time?
Edit: I'm referring to the one on Ebay 99kamarokid posted....
Old Jul 13, 2006 | 07:15 PM
I don't see anymore of the one's like I got listed on Ebay but this is the sellers email if you want to contact them and see if they still have them. purchase4lessnow@yahoo.com
I don't think the distance really maters the whole thing is under vacuum so the oil will make it to the can and no father once it gets there.
Old Jul 13, 2006 | 07:26 PM
dummer's Avatar
Thanks I will email them, it looks better tan the one in the link posted earlier.
Yeah, I doubt the distance hurts anything either ....
That Engine bay looks sweet!
It has a drain plug on the bottom but I can't really get to it so I'll just unscrew it from the wheel well and them take the plug out and let it drain.
Old Jul 13, 2006 | 07:36 PM
Thanks.
Yea its the nicest one I found for the $40 shipped I paid for it.
It's very well made not cheep at all like alot of them you see on Ebay. And you can remove the top too if you want to to clean it out.
Old Jul 13, 2006 | 10:07 PM
FireSilverLullaby's Avatar
Yeah I got one just like that from ebay, but i have clear hoses and I can see oil in both of them. Does this mean the catch can is not doing its job 100%.
Old Jul 14, 2006 | 12:23 AM
BobbyWS6's Avatar
try installing it on the passinger side of the car and shorten the distance. I would be courius to see the result after about 1,000 miles. My be that you engine is doing just fine and the small amount in your hose is just a coating that would result even on a newer motor. Good Luck. It is a simple system and I bet your Can is doing just fine.
