Pcv Delete
Old Jul 19, 2006 | 03:28 PM
nexvctm2001ss's Avatar
Default Pcv Delete
WHAT DO I NEED TO DO TO GET RID OF THE PCV ON A 01 SS? WHAT PARTS DO I BUY? WHAT PARTS DO I REMOVE? ECT. ECT. ECT.
Old Jul 19, 2006 | 03:37 PM
FstBlkz28's Avatar
Buy a breather. I got my Metco from Year One , it screws right onto the oil filler tube. Then all you have to do is pull out all the lines. Theres a line that plugs into the back of the dr. side valve cover, and goes to the back of the pass. valve cover where it Y's. Pull out all that tubing, and continue up to the front fo the valve cover, then pull out the PCV valve and pull the tube off the Intake where the PCV line went in.
Once you've got all that out, just plug up all the holes and install your breather.
Old Jul 19, 2006 | 03:41 PM
Thanks Man... Wouldn't Happen To Know What To Use To Plug Up Where The Lines Went? Also Does It Blow Oil Everywhere?? Heard Stories That It Does.
Old Jul 19, 2006 | 03:46 PM
FstBlkz28's Avatar
I've got all my holes ghetto plugged right now until I can do a cleaner job on them. On the tubes on the pass side valve cover, I took bolts that were just small enough to get the threads started on the tubes and I just drove them in far enough till they were tight. On the hole in dr. side cover, I actually took a bit of rubber exhaust hanger and shoved it in the plastic peice that you will pull out of the hole originally with the rest of the tubing. It's ghetto, I know but it was a last min mod so I didn't have any time to fab up clean plugs or anything
When the car is running you can see some "smoke" coming out of the filter everyonce and a while. But by no means is oil getting thrown around the engine compartment, and theres no film or residue from what I can tell either.
Old Jul 19, 2006 | 03:49 PM
2 SSlow's Avatar
11$ autozone breather, $4 ail cap, drill about a "1 hole... Then i put a small breather on the driver side cover in the back...
Old Jul 19, 2006 | 03:52 PM
2 SSlow's Avatar
i bought an assortment of vacuum line fitting caps or whatever
Haven't noticted oil anywhere else under the hood...
Old Jul 19, 2006 | 03:54 PM
FstBlkz28's Avatar
Damn thats nifty ... wish I had thought of that back when I did mine. Woulda saved some $$
THANKS FOR THE INFO. GUYS THINK I WILL DO THAT 2NITE
Old Jul 19, 2006 | 03:56 PM
2 SSlow's Avatar
i think total cost on mine was right at $30 for everything... That small *** breather was almost as much as the big one... $10 and $11 for the breathers.
