Belt Squeaking @#*($&
Old Jul 22, 2006 | 05:36 PM
Ls1Won's Avatar
Default Belt Squeaking @#*($&
Well my car broke down and I had to tow it home, I decided to tow it with a pickup and used the tube below Now I guess that the tow rope rubbed and the pully started squeeking it looks like it is wobbling a little bit though I don't know if it wobbled before or if it is supposed to wobble. Help
ls1won
Old Jul 22, 2006 | 05:59 PM
SS1875's Avatar
ls1won
It shouldn't wobble if it's tight ..maybe check the bolt first. If it is tight and is wobbling, could be you did some damage that can't be seen...hopefully you didn't hurt the crank and just got the pulley out of round...good excuse to get an UD then.
Old Jul 23, 2006 | 12:44 AM
2002ssls1's Avatar
Why would you put a rope around the pulley to tow the car in the first place?
Old Jul 23, 2006 | 01:51 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
That was what I was wondering....but it looks like he said "tube" so I can only help but think he had it on the front sway bar.
Old Jul 23, 2006 | 02:51 AM
mmmchickenboy's Avatar
the crank pulley is actually 2 pieces of metal with a layer of vibration damper stuff in between, right?
my guess is that you goofed up the relationship between the center hub and the outer section with the belt grooves. now it wobbles.
i can't think of a better time for an underdrive pulley, if you're into that sort of thing.
i don't care for them.
