A.I.R Delete Finished
Old Jul 31, 2006 | 08:46 AM
surgence's Avatar
Default A.I.R Delete Finished
Well I did the A.I.R delete on Saturday. I bought the block-off plates for Speed Inc. For any newbies out there, it is a very simple task! This was my second time to touch the ls1 engine (1st time being the lid). So heres some simple tips that might help the lazy people that dont want to search.
(sorry I dont have pics I forgot the camera)
1. The flap under the driver side fender is a lifesaver!! Its 2x10mm bolts and the A.I.R pump is right above the opening.
2. There are 9x10mm bolts altogether (2 for the flap, 4 for the lines to the exhaust manifolds, 3 to unbolt the AIR pump.)
3. There is a unit at the back of the intake (DS). The lines to the exhaust manifolds connect to this. There is also a small plug ontop of this unit. I used a screw to close this plug (You'll see it if you dive in there).
4. THIS IS IMPORTANT. The block off plates are definitley NOT thick enough to just bolt down and go!!!! I had to use 2 washers on each bolt to get the plate to seat on the exhaust manifolds. I also used some gasket maker, I'm not sure if you could use the old gaskets or not. A quick way to solve thickness problems is to match the amount to washers (thickness) to the original lines taken from the manifolds.
CONCLUSION:
It definitley cleaned up the engine bay! I would say this is the only thing it does. I thought that the pump was making a high pitch whistle only to find out its back! So now its back to the drawing board to figure out where the air leak is.
Hopefully these pointers will save you some time. A search will help too but I wanted to add my contribution.
Old Jul 31, 2006 | 08:55 AM
YellowMonster87's Avatar
congrads man....so when you doin the cam swap ?? i hear its really simple jus like a couple bolts hahahaha
Old Jul 31, 2006 | 09:32 AM
00pewterWS6TA's Avatar
cool. yellowMonster we should hook up sometime.and rum em. whats your mods?
Old Jul 31, 2006 | 10:04 AM
FireSilverLullaby's Avatar
so has you ses light gone off
Old Jul 31, 2006 | 10:26 AM
surgence's Avatar
Not yet, but I head it takes a few days for it to kick in!
Old Jul 31, 2006 | 10:57 AM
sorry to jack the thread, ya anytime man jus shoot me a pm im heading to 66 tomorrow with some guys but we should def get together sometime
Old Jul 31, 2006 | 11:33 AM
LS69TA's Avatar
Mine was triggered for a while, but I still had the pump hooked up ( I just got rid of all of the hoses). Once I pulled the pump off of the car, the light went away.
Old Jul 31, 2006 | 12:10 PM
Christopher387A's Avatar
When you remove this, do you have to pull the fuses out?
Old Jul 31, 2006 | 12:19 PM
surgence's Avatar
to tell you the truth I havent touched anything to do the electrical system! I dont know if this effects anything or could have jolted me but I was listening to some music from the cd player when I pulled it. Any plugs that were left open I taped off with electrical tape.
Old Jul 31, 2006 | 01:31 PM
TORCHD 02 TA's Avatar
i will be orderign the block off plate today from thunderracing and be done with the AIR Pump.
ohh yea, hp tuners alrady tuned it out
Old Jul 31, 2006 | 08:50 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I removed my A.I.R. **** about a month and a half ago and just recently (three days ago) removed the fuses. It doesn't hurt anything if you leave them in as long as it is tuned out of the computer
Old Jul 31, 2006 | 08:51 PM
Z28XTC's Avatar
Doing mine this week
Old Jul 31, 2006 | 10:41 PM
Z28/2002's Avatar
I used the heat shields from the rear of the car to make my own block-off plates instead of buying them cause I'm a cheap ***.
Old Aug 1, 2006 | 08:03 AM
TheBlurLS1's Avatar
That's what she said...
You need 2 blockoff plates, not just 1.
I have a big sheet of like 16 guage stainless behind my house that I boosted from my old job. I've made all kinda block off plates out of it.
Old Aug 1, 2006 | 08:16 AM
surgence's Avatar
Welp the SES light came on today! So it lasted 3 days.
Old Aug 1, 2006 | 01:37 PM
i actually did not order the block off plates yet.. i am gettin LTs that have no emissions on them. So i do not want to waste my money
Old Aug 1, 2006 | 04:38 PM
sarge28's Avatar
Easiest thing to do is to get a tube cutter cut the A I R hoses (the metal) ones, this way you just bolt the plate and a small amount of the hose. dont cut to short leave some metal so you can crimp it and then weld the small opening, and bolt right back up. My SES light came on almost instantly. I,ve driven with the fuses out and with fuses in no change either way.
Old Aug 1, 2006 | 04:53 PM
Cantalope Kid's Avatar
With the SES light on do you see any performance difference...the reason I ask...I thought when the SES light when on the computer went into "LIMP HOME MODE?" which would adjust your fuel/timing setting to a very conservative setting to help you get the vehicle to a service station to get the SES issue resolved. Let me know because I want to rip all that A.I.R. Whistling junk out too...When I start my car AND when I punch it I sware I hear some leaking noise with idle and a whoooooosh out the sound out of the passenger side rear exhaust pipe...Probably just me or that damn LS1 engine knock we are supposedly all USED to living with!
Old Aug 2, 2006 | 11:30 PM
TheBlurLS1's Avatar
The car will run no different. Only "Limp Mode" I can think of is when the MAF stops working and it switches to the low octane spark tables?
