Ported LS2 manifold
Old Aug 5, 2006 | 11:48 AM
MNR-0's Avatar
Default Ported LS2 manifold
I recently did a back to back test on a ported vs. stock LS2 manifold. Bear in mind that all the testing I have seen so far indicates that 90/LS2 vs 75/LS6 is on par (with tuning).
The testing was done on the same day, same dyno within hours of each other, same car and tune. Nothing was touched bar changing manifold.
The problem with the LS2 2-pice is just that - its a 2-piece where the joins result in steps inside the runners. The quality of joinery is dubious at best and after examining one up close, can see why the LS2 seems such a hit-n-miss affair.
I will post some pics of the port job when I can find my camera USB cable. Here are the dyno sheets...
POWER
TORQUE
I picked up 10rwkw everywhere, not just the top end. Furthermore, the lower down, the greater the gains were. With porting, these LS2 manifolds seem to offer significant efficiency gains, especially around peak torque.
Torque gains were in the order of 45-50NM, but the seat of the pants feel, which the dyno can't measure (below 5000RPM) indicates there are greater gains still. Feels like a smaller cam with more torque. The just-off idle airflow stalling effect is totally gone, and the pedal response is smooth and progressive - holding the torque and increasing power the more you pedal it - just like a carby.
Mark Busher from MBP Performance did the port job, taking out a full 2L coke bottle of plastic. All the ported manifolds I have seen to date have only been ported into the 3rd runner. Mark ports them all the way to the back, port matches the runners, radius edges the bell mouths and removes the ribs in the plenum.
Old Aug 5, 2006 | 12:12 PM
Red99TA's Avatar
So the ported LS2/90 was worth 10rwkw and 40-50NM vs. the LS6/stock TB? How about a conversion to HP and TQ? (I'm too lazy to find the conversion myself).
Old Aug 5, 2006 | 12:19 PM
lastcall190's Avatar
10rwkw ~ 13rwhp, 40-50nm ~ 30-37lb/ft FYI... looks like some decent gains, I've heard that the multi piece design is what truly is a killer, I guess as you found out.
-J
Old Aug 6, 2006 | 11:02 AM
MiaSSmaro98's Avatar
so an ls2 ported is better then an ls6?
Old Aug 6, 2006 | 04:08 PM
1FST99Z's Avatar
good stuff to know. thanks for the graphs. it definitly picked up accross the board.
Old Aug 8, 2006 | 08:15 AM
mbp1's Avatar
Default manifold LS2
POWER
http://users.bigpond.net.au/thompson...ted_ls2_hp.jpg
TORQUE
http://users.bigpond.net.au/thompson...ted_ls2_tq.jpg
Anyone can feel free to contact him on 0418 506 615 or email at mbperformance@bigpond.com.
spanks's Avatar
I was present at this test and the response from the manifold was awesome...much better port job than pics available from ls2portworks as the porting doesn't seem complete in plenum by viewing the pics,it seems to only have been ported to the 3rd or 4th runner.Manifold from MBPerformance is ported all the way to the rear of plenum and runners are ported as far as the eye can see...an excellent job and excellent results speak for themselves.
Old Aug 8, 2006 | 03:05 PM
does this guy port ls6 manifolds?
Old Aug 9, 2006 | 08:49 AM
spanks's Avatar
Yep...
Old Aug 9, 2006 | 12:39 PM
were can i get a hold of him?and price?
Old Aug 10, 2006 | 09:00 AM
spanks's Avatar
Old Aug 15, 2006 | 04:24 AM
mbp1's Avatar
Default fully ported LS2
ls there anyone in the stats that has fully ported the LS2 manifold
Old Aug 15, 2006 | 03:05 PM
86 IROC's Avatar
I've heard that Formatto does, and a few other guys have posted about doing them.
