custom ram air
Old Aug 10, 2006 | 12:12 PM
DSRCAM's Avatar
Default custom ram air
i have this question a friend of mine said u can make a custom ram air by add plastic hoses on the side of the grille like in this pic and have the air get sucked in by the air lid can anyone show me pics of this mod??
Old Aug 10, 2006 | 12:16 PM
Eatinstang4life's Avatar
Thats gay just do the free mod by cutting the plastic under air filter you get more air that way than what you are talking about.
Old Aug 10, 2006 | 12:18 PM
DSRCAM's Avatar
i did the free mods already, and ive seen the mod on a camaro ss he gained like 15 hp from it but i wonder what he used!
Old Aug 10, 2006 | 12:33 PM
2000TransAmWS6's Avatar
i have no pics of it, but a friend of mine did it. it seems to me that it would be pulling in cooler air than with the free ram air mod.
i do know that you would have to relocate the windshield washer fluid container.
Old Aug 10, 2006 | 12:35 PM
Out1aw's Avatar
Good idea... just dont put the filters down there (seen it before) due to rain.
Old Aug 10, 2006 | 12:47 PM
BIG_MIKE2005's Avatar
You are gay.
This idea has already been done. It is very effective on Camaros. It does deliver more cooler air. I believe the guy cut his airbox like for the free mod, then made a custom plate that attached to the bottom of the airbox. He then ran (2) individual hoses down from the plate & attached them to the backside of the holes in the front bumper.
If I remember right he said it gave him a pretty decent increase for the type of mod it is. Don't get discouraged by douch bags with no knowledge like the guy above. Keep searchin & you will find exactly what your lookin for. I know if I had a Camaro I would do this mod.
Old Aug 10, 2006 | 12:48 PM
ZL1Killa's Avatar
yall realize that the free mod causes your AITemps to run high while sitting still? and probably warmer than normal moving slowly.. but once you get going....
Old Aug 10, 2006 | 01:09 PM
MjMaro's Avatar
https://ls1tech.com/forums/showthrea...light=big+gulp
https://ls1tech.com/forums/generation-iii-external-engine/286313-pics-custom-ram-air-lid-ftra-gone.html
It's been done before, but still a pretty cool thing to do if you can pull it off. There are more threads on it, those are just a few.
Old Aug 10, 2006 | 04:22 PM
irnbru83's Avatar
pfft, why would you want to sit in idle anyway?
Old Aug 10, 2006 | 07:48 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
Originally Posted by BIG_MIKE2005
You are gay.
yeah...it's a cool idea...I did it on my '86 silverado flatdeck and there was a post yesterday or the day before showing what he did on his t/a --he took out the fog lights..
Old Aug 10, 2006 | 07:49 PM
NHRAMAN's Avatar
Talking
I know no idle.
Old Aug 11, 2006 | 10:38 PM
Havok2's Avatar
i have that mod.
gained .09 tenth and 1.1mph on my times
need to go back to see if i gained more, when i went, too busy, only ran 1 time.
Old Aug 12, 2006 | 05:35 AM
outkast6991's Avatar
i also did the "sux2bu"mod on my 98 z.i used a 1/8 steel plate with 2 4 inch pieces of exhaust pipe welded to it.for hose i tried using plastic drainage pipe but wasn't flexible enough so i ended up with dryer hose(the metal stuff).as far as gains my previous best was in 50 degree air.i went to the track last week and ran 3 passes all of them within .050 of my best but in 85 degree air and a da of 2400ft.i would say it is worth at least 2 tenths and 2 mph.good luck man
Old Aug 12, 2006 | 10:52 AM
camaroextra's Avatar
How is that gay? Im just curious?
I did it to my car, I used two 4" daimeter hoses on each side, hidden behind my billet gril. You have to remove the windshield washer resoviour, and cut holes in the bumper support. You also have to take off the whole front bumper cover. But its worth it, it shoves air down your engines throat.
Old Aug 12, 2006 | 01:08 PM
SUX2BU's Avatar
This works, there are one million threads about it.
Old Sep 2, 2006 | 11:27 PM
Asmodeus's Avatar
You also get more dirt, more crap, more debris, more tennis elbow from cleaning your filter every week... yeah real good idea, you go do that to your T/A there buddy..
Old Sep 3, 2006 | 12:18 AM
2mffZ28's Avatar
Staging lanes????????? hmmmm
I did fra and in traffic I saw over 150 degrees iat on a 95 degree day. Can you say KR.
I got rid of my ftra because of my trans cooler, I'll bet it was a bit better with it.
Be careful of fra and summertime heat............WOW was I surprised when I started logging iat's
This mod is very interesting.
As far as dirty air filters go....................nevermind
Old Sep 3, 2006 | 07:47 AM
Andros's Avatar
I always wanted to see the camaro have a big hole instead of 2 and one block in the middle, it'd be more effective. The fog lights can be used for brake cooling.
