truck throttlebody on a ls1??????
was off a truck and the casting numbers were
identical; differences were the shaft cam (smaller)
and the coolant and PCV bungs. I swapped over
the PCV snout but just cut off the whole coolant
boss, fittings and all. If it's a cable throttle truck
I believe you will find the same.
