Bump Stop Mod?
Old Aug 11, 2006 | 12:52 PM
gyrene2003's Avatar
Default Bump Stop Mod?
Thinking about doing this mod, is it worth it?
Old Aug 11, 2006 | 12:54 PM
777's Avatar
777
Yeah, it's free. It let's the throttle blade open up more. Don't let it go past 90* though or you will be in some trouble.
Old Aug 11, 2006 | 01:00 PM
gyrene2003's Avatar
ok, awesome, thnx! oh and 777, i sent u a pm.
Old Aug 11, 2006 | 02:19 PM
knight rider WS6's Avatar
Buttin' in here guys, but noboby answers me on this. Do you have to tighten the throttle cable after this? Mines pretty loose anyways.
Old Aug 11, 2006 | 03:18 PM
Sneakyws6's Avatar
On the tree
This has nothing to do with the throttle cable. All this does is removes some material from the bump stop on the throttle body so that the blades are actually open and paralelle to the incoming airflow.
Old Aug 11, 2006 | 03:31 PM
jimmyblue's Avatar
Moderator
You may well have a bump-stop that allows the blade
to open fully, but a cable with so much slack that you
can't make it. It -all- needs to be snug, and one key
piece from the throttle cable pulley cluster to the pedal
is non-adjustable.
Get the bump-stop to where it will open to dead center
by ruler, then see if your pedal, matted, will get you
there. If not, fabricate a spacer or bend the pedal arm.
Old Aug 11, 2006 | 03:34 PM
TransAm_00's Avatar
If this would really affect the performance that much,,, GM would of done it.
Old Aug 11, 2006 | 03:39 PM
777's Avatar
777
Just like a having the lip on the throttle body worth 8rwhp, right?
 Michael S. Palmer
Old Aug 11, 2006 | 03:49 PM
ZL1Killa's Avatar
...... just make sure you are getting 0% throttle at idle and don't worry about it... jeez; free mods aren't what they are cracked up to be in my opinion. research before doing your mods and think about what can or can't happen after you do them
Old Aug 11, 2006 | 04:02 PM
chewy99ws6's Avatar
I noticed a slight diference after I did mine.
Old Aug 11, 2006 | 05:01 PM
nvrlast's Avatar
I just did mine also and did a p and p to the tb and noticed atleast a 4 hp gain and tons of throttle response and the tb opens up quite a bit more I wish I could have takin pics of befor and after cuz mine was pretty bad befor i ground down the stop.
Old Aug 11, 2006 | 05:14 PM
jay_99z's Avatar
They probably would have done a heads and cam swap too. I wouldn't bother with those either since GM didn't....
Old Aug 11, 2006 | 07:11 PM
bene's Avatar
Trunion King
Haha, funny man... GM also made the Pontiac Aztek, you should go ahead make your T/A look like an Azztek.
Old Aug 11, 2006 | 07:25 PM
WhiteStripes's Avatar
^^ LMAO. That's some good stuff right there.
Old Aug 11, 2006 | 07:31 PM
nvrlast's Avatar
The reason why its like that is the poor quality of cast and molding that they do for the TB's it would cost to much money to get everything right on the car.
Old Aug 11, 2006 | 10:33 PM
Ahmadi6490's Avatar
Any write up on the bump stop mod?
Old Aug 11, 2006 | 10:44 PM
777's Avatar
777
I wouldn't go as far to say that. GM should be able to cast it right to begin with. I mean if I go by what you are saying the head can be cast with half the exhaust port closed haha.
Old Aug 11, 2006 | 10:53 PM
Havok2's Avatar
oh, you mean like our weak 10 bolts? LOL
Old Aug 11, 2006 | 11:14 PM
jimbo98z's Avatar
And put a real rear axle under the car. And given it true duals from the factory. And had a fully adjustable suspension stock. Heck, why not put a big ol' twin screw blower on it?
Bottom line is, at some point no matter what the car company, they all say "thats enough" eventually, or worse "that's good enough". That second phrase has lead to the demise of many things...
Old Aug 11, 2006 | 11:28 PM
LS1DER's Avatar
https://ls1tech.com/forums/generation-iii-external-engine/420817-bumpstop-mod-my-first-try-writing-install.html
Excellent write up with pics
