Dont use this mod!!!! Free Ram Air is Bad
I currently have the FRA mod.....
I can't believe i'm saying this, but, it DOES NOT WORK.
Anyone who thinks otherwise can easily scan their IAT's via a scanner and watch what happens to the car on an warm afternoon drive.
The car WILL see lowere IAT's after a constant speed is kept, but i wonder if you would see the same reduction via the stock airbox(uncut)....
As soon as the car is stopped and idling, IAT's will skyrocket through the roof, and the car's performance will suffer.The IAT's do not immediately drop as one would think either. I would be willing to bet that the IAT's of a FRA car are considerably higher than that of a stock airbox car that has sat for let's say.....5 minutes, and then made a 1/4 mile blast.....at the end of the 1/4 mile, i bet the stock airbox would still be lower IATs...it takes ALOT longer for the IAT's to drop than it does for them to rise.
I was a hardcore believer in the FRA mod, but the scanner does not lie guys. It's what is known as a urban myth in the LSx world
Originally Posted by GuitsBoy
Buy some cheap sheet metal from home depot or lower and fashion your own FTRA. This will block most of the hot air from raising off the radiator and going directly into the lower airbox.
Even Fast Toys website says that their ram air system will increase temps because you are blocking part of the radiator with the ram air system.
I'm leaving mine as is until I can draw better conclusions. There's always a trade off with mods and as of right now, I don't see the positives outweighing the negatives.
Originally Posted by Marblehead
Your blocking the hot air coming off the radiator but now your blocking part of the radiator with the ram air system which will increase temps because it's getting less cool air to the radiator.
Tech Resident
Originally Posted by minivette
The glare. I think that is the worst picture I have ever seen.
You only have to drop 6" or so below the lower airbox to drastically reduce your idle IATs, and this will obstruct very little of teh radiator. Furthermore, the sheetmetal is angled forward, so it does not rest against the front of the radiator. Theres plenty of clearance to flow air through there. After adding the sheet metal to mine, I noticed no increase at all in ETCs, yet a good reduction in IATs at idle and low speed city driving. Perhaps your concerns are valid in theory, but in practice the difference is almost negligable.
Will My Car Run Hotter?
Because the lower ram air plate does block a portion of airflow going to the radiator, your car will run a little hotter in stock and go traffic (10-15 F). However, we have done extensive testing on the kit and have not experienced any overheating problems even in warm climates like Hawaii, Florida and California. Highway driving is not affected. In the rare event that outside temperature gets so hot that cooling performance is drastically impacted, the lower portion of the kit can be easily removed in less than 5 minutes, leaving the kit installed and functioning as a cold air intake system. Once the temperatures come back to normal, you can just re-install the ram air plate.
You can improve cooling with the installation of an aftermarket fan switch or with aftermarket computer programming which will turn the factory fans on sooner. A 160 thermostat is also beneficial.
#32
FRA is a joke.
#34
So is there any cheap way to un-do the FRA?
I know GuitsBoy said you can go to Homeless Depot and make your own, but pictures would sure help, along with some instructions.
#35
Im stickin to my belief that the FRA isnt worth the cutting and cleaning and potential increase in IAT at rest. Might as well spend your time punching holes in the hood for more air
#36
Tech Resident
#37
A lot people are under the impression that GM purposely does things to slow our cars down. There's a very good reason why that plastic piece is there. The baffled air lid is a good example of pure nonsense by GM. What person who buys a performance car would mind the pleasant sound of air rushing into the intake?
#38
Well, I've done both the FRA and FTRA. The FRA was on a 98 V6 I had. I have the FTRA on my current '99 Z28. I don't remember any difference in performance on the '98. The air filter did get a LOT dirtier with the FRA though. I checked my filter a few months after installing FTRA and it actually looks very nice. There's not nearly as much crud. With the FTRA I did notice a very slight increase in milage and definite increase in throttle response at speed. I would say there's a difference.
#40
1 Post
Of course it gets dirty faster because of more air flowing. You have to do this before you buy a cold air intake system and when doing this and adding the Whisper Cold air intake i noitced a nice gain and better MPG. Just clean the filter once a month or if you dont have a K&N buy a new paper filter monthly.
