K&N FIPK guys check in... whining...
Originally Posted by 00454sscamaro
all those type of intakes make a whine.. even on little nearly stock imports. the filters really the cause of it, too small for the air going in.
Have you ever even seen a FIPK for a F body, the filter has more surface area than a stock sized drop in filter!
^^yea the filter has enough surface area, if you do the math you would see that filter is flowing well enough for the engine. I have the volant fipk and i get the same noise but it seems to go away after a few minutes.
