mobil 5w40 truck and suv oil!
Old 09-01-2006, 09:52 AM
sickws698's Avatar
The market
Old 09-01-2006, 10:05 AM
JohnnyC's Avatar
Synthetics were designed to maintain their viscosity and lubrication properties under extreme temperature ranges. They also have better volatility control which helps them resist oil consumption better than conventional oil. Running a synthetic oil (despite the misconception) does not always mean that you can go longer between changes. Synthetics do keep engines cleaner longer, and tend to maintain their properties longer than conventional oils, but extreme driving conditions can still cause synthetics to become contaminated in relatively short time periods. The only way to be sure is to test your oil, so blindly running a full synthetic for 10K miles or more without testing it could lead to problems for some driving habits and environments. The reality is that, for most normal driving conditions, a conventional oil is very effective for the LS1 if changed regularly. (I.E., daily drivers that do not see the drag strip or extreme environmental conditions). I have seen LS1s and many others run for 100K+ miles on conventional oil with no problems. For those of us who do not fall into that category, or do not mind spending a little extra $, the synthetics become a good choice. You will never be wrong for choosing a synthetic, but you aren’t always necessarily wrong for choosing a conventional either.
Old 09-01-2006, 10:27 AM
SEB
SEB's Avatar
I am changing my Oil this Weekend & was going to run the Royal Purple 5W30 Synthetic, Is that to thin of oil for my LS1?
Also what Oil Filter should I use?
Does anyone know what the part # is on our Fuel Filters? 2000 LS1
Old 09-01-2006, 10:33 AM
JohnnyC's Avatar
As seen in some of the earlier posts, some people have oil consumption problems when running the 5W-30 because of the PVC system effect on the lower viscosity oil. I have been running 5W-30 Mobil 1 in my LS1 for 40K miles and I never have to add oil between changes (knock on wood). You will not "hurt" your engine by running 5W-30, but you will have to keep a close eye on your oil level between changes. If you do experience oil consumption,then try a different viscosity like CHACOTACO and others have reccomended in this thread.
Old 09-01-2006, 10:41 AM
TRANSAM_2000's Avatar
i put lucas oil stabilizer in with my 5w30 m1 will that help not having to put oil in so much
Old 09-01-2006, 10:52 AM
JohnnyC's Avatar
no, and was probably a waste of money.
Old 09-01-2006, 11:08 AM
DAMN IT!!!! So i can get m1 0w30 or 0w40 and not use as much oil.
Old 09-01-2006, 11:17 AM
LILWS6's Avatar
only the 0w40 will make it take less oil do not get the 0w30 i run mobile 1 0w40 and have no poroblems with it
Old 09-01-2006, 12:27 PM
Dom
Dom's Avatar
I didn't need oil analysis to tell me M1 5W30 is crap. I used to get crappy oil pressure with it. Then I went with M1 5W40 or 0W40, forget which(whatever the truck oil is), then pressure went up 5-10. Then I switched to Castrol 0W30 and the pressure was about the same during easy driving and it actually might have increased during WOT. That definitely shows how thin M1 is. I think I get a solid 60psi now @WOT. I don't think I even got that with W40 M1.
Old 09-01-2006, 12:31 PM
Since i have already put 5w30 m1 in my car when it gets low can i add m1 0w40 or 5w40 to it And the next ime ill get the thicker oil
Old 09-01-2006, 01:25 PM
JohnnyC's Avatar
There is no need to panic over this-just keep an eye on your oil level and put in the 0W40 or 5W40 when it is time for a change.
Old 09-01-2006, 01:31 PM
  #32
TORCHD 02 TA's Avatar
Originally Posted by ChocoTaco369
wow, you are so wrong it's not even funny. mobil 1 30W's are far too thin for the LS1. this is why they consume oil and tick - oil is too thin. for all you guys out there running M1 30W, get your oil analyzed a few times. you'll stop using it on your own.
mobil 1 0W-40 will work, also. it's good oil. however, GC 0W-30 is better than all mobil 1's. the GC 30W is as thick as a mobil 1 40W, but it's a superior oil base. you can get that ONLY from autozone.
i can not find a Mobil 1 5W40 or GC at all in my area
Old 09-01-2006, 02:23 PM
  #33
Tech Resident
ChocoTaco369's Avatar
no worries, order it online:
https://ls1tech.com/forums/general-maintenance-repairs/539268-found-online-store-sells-gc-0w-30-a.html
it's $8/qt and seems pricey, but you get free shipping, no tax and when you factor in time and gas it takes to run to the store, the price is pretty even. you're only paying ~$6 more than mobil 1, but it protects so much better, it's a small price to pay.
Old 09-01-2006, 04:28 PM
  #34
BayAreaSS's Avatar
I've been using 10w30 and my car eats it up. I changed my oil about 2,800 miles ago and i have added 1 quart. Its almost time for a oil change. What weight do you guys suggest. Im tired on adding a quart and checking my oil all the time. Damn that reminds me..........i should check it before i drive it tonite!!
Old 09-01-2006, 05:30 PM
  #35
everone suggests German Castrol (GC) 0W30 MAKE SURE IT IS MADE IN GERMANY.. or if you cannot get that the next perferred brand is mobil 1 5W40
Old 09-01-2006, 06:54 PM
  #36
BayAreaSS's Avatar
Ok thanks. I'll check into it on the weekend
Old 09-01-2006, 06:59 PM
  #37
Dom
Dom's Avatar
Did you look? There is plenty of GC at the Autozone on Bloomindgale/Army Trail. It's always there when I need it. I had no problems finding either of the oils. Walmart on Army Trail always had M1 5W40. Recently they didn't although I'm sure it's because of the switch to different name. They probably have it now.
Old 09-01-2006, 08:57 PM
  #38
gillbot's Avatar
How do I fing the GC 0-30, i've yet to find it anywhere. They stopped carrying my Mobil1 15W-50 here locally and i'm being forced to either find a new grade or switch brands.
Old 09-01-2006, 09:07 PM
  #39
Tech Resident
read post #33.
Old 09-01-2006, 09:29 PM
  #40
99camarols1m6's Avatar
these are the oils higher than a 30 weight i have to choose from where i can get real cheap or free, what would you suggest: Amsoil 15W-40, Mobil 0W-40, Mobil 5W-40, Mobil 15W-50, and Penzoil 5W-40. (all full synthetic)
Quick Reply: mobil 5w40 truck and suv oil!
