crank pulley help!
On this pic notice the other "washer" like metal underneath the actual washer...its been awhile since this piece was put on but I believe that has broken off of the crank...am i right??
At this point i would cross your fingers and hope the crank is not damaged, if it is not then all you are looking at is a new bolt and pulley. The opening in the front of the crank should only be big enough to fit the end of the bolt in the with not much play around the edges. Ifnyou ahve more than that then the crank is done as well.
I know how to install a pulley as I'm sure Vandall does as well. Haven't had an issue since I put the stocker back on.
It didn't do any harm to the crank. I just put the stocker back on until I have enough cash to get another. If you can push the ASP on by hand it's gonna slip if you reinstall it.
After seeing one more ASP slip....I think I'll go with another brand.
