My LTs might be banging a bit.. HELP
any help would be greatly appreciated!
Bene does your LTs hit your stering link at all?
my motor mounts have 40k miles on them. i did loosen my motor mounts but i swear i tightened them up.. I think that it is hitting some where else
Need more HELP!!!!
Bene, mine is not hitting the stering linkage, it is about and 1/8" away from it. Also it is 1/8 from pasasnger side k member.. i pounded the floor board in.. What i am really concerned about is the mother fvking vibration.. it is slgiht in at any RPM but very noticable at 2400 RPMs what the hell gives?????? i think i need to get it on a drive on lift with the motor running and see what is happening..
any other ideas?
hey do you have a sound clip of your set up?? i am thinking of gettign the Sweet Thunders.. my magnaflows are really quiet..
More than likely though, it's the motor mounts. If you go with LT's, you almost always need poly motor mounts.
I don't know exactly what GM did, but the material they used for the mounts SUX! The motors really bounce around and move in the engine compartment....some much more than others. There's too much travel in the motor and not enough clearance with the headers....simple (but PITA solution).
