View Poll Results: which intake for my set up?
LS6
20
62.50%
fast 78
1
3.13%
fast 90
11
34.38%
Voters: 32. You may not vote on this poll
what intake??
Old Sep 13, 2006 | 09:20 AM
jblack245's Avatar
Default what intake??
im going with a head cam and full bolt-on setup. tr224 cam, afr205 head and full bolt-on which intake would be best for my set up??
Old Sep 13, 2006 | 11:29 AM
jblack245's Avatar
13 views. if u have nothing to say vote please
Old Sep 13, 2006 | 12:08 PM
GREATWALLTA's Avatar
I have the same cam that you gonna put in, The LS6 intake well work plenty good for your setup right now. The FAST 90/90 is only needed under extream heads and cam setups which needs a lot more air. I sold my LS6 to my friend and got a FAST 78 right now, but for a good deal. But honestly in your case LS6 well due just fine all the way up to 500 RWHP.
Old Sep 13, 2006 | 01:02 PM
bjamick's Avatar
ya ls6 will work fine and you can also port the ls6 if you want to..
Old Sep 13, 2006 | 01:07 PM
michael402z06's Avatar
go with the ls6. no need for the fast for your setup.
Old Sep 13, 2006 | 02:11 PM
parbreak's Avatar
LS6 will be perfect.
Old Sep 13, 2006 | 02:16 PM
BLK02TA's Avatar
Another vote for an LS6.
Old Sep 25, 2006 | 06:51 PM
Raptor99's Avatar
If you can find a good deal, go with the 78. When I got mine, most of the LS6's were going for $300+, and I got the FAST for $500. Definitely glad that I did
Old Sep 25, 2006 | 08:58 PM
Tainted's Avatar
+how ever many for the LS6 the FAST wont yeild enough gain over the LS6 for the moeny it costs unless you got bigger cubes or heads/cams/turbos whatever
Old Sep 26, 2006 | 05:05 AM
300bhp/ton's Avatar
setup correctly both the FAST intakes have to potential to make more HP over the LS6, this is due to larger openings and better intake plunium design.
Whether you consider the HP/$ to be worth while is a different matter entirly.
Might be worth checking out the new Typhoon manifold from Professional Products.
Old Sep 26, 2006 | 06:58 AM
TheBlurLS1's Avatar
That's what she said...
How much money do you have? That $1100 or so for a FAST 90/90 setup could go a LONG way towards suspension/built trans/stall/gears.
For $1100 you could probably get a REALLY nice nitrous system going as well. If you're just looking for places to drop some cash, go for it, but you can do alot of good in other places.
For example: My car will not spin the tires in 1st gear on the street unless I rev it up and side step the clutch.
It doesn't impress the highschool kids any with the "OMG dOOdZ! That car will smoke the tires from 50mph!!!!!!!!111oneeleven" bullshit, but I put BUS LENGTHS on a boltons/150shot 05+ Mustang GT the other night............ from a dig....
Old Sep 26, 2006 | 07:34 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I want to see some member results on this, but at the same time I don't want to see someone get screwed.
