Car is studdering and miss firing HELP!
2 nights ago i changed my plugs and it was driving fine as well, i raced it and everything with no problems.
well today it was raing pretty hard. so i drive my car to work and i leave for lunch and i notice my car at idle is heistating and violently shaking and i try to rev it and it will barely even rev. thought i sucked up some water cus i have the FRA mod done. so i go back to work and park it later that night when i leave it does the same thing then i hold the rpms at 2k and it stays then all of the sudden bam everything is fine. drives fine.
so i go to auto zone to get the codes pulled. and of course i have the rear o2's and air delete codes showing but. 9 errors pulled up including
p0113
p0140
p0152
a couple were for the o2s and air and he said there was like a misfire on number 6 cyl.
im going back in a minute to make sure all the plug are tight so that isnt the problem. and clean my MAF what should i use to clean it?
any hlep would be apprecaited.
thanks
also this happened after i got a full tank of gas at chevron?
where is a data base to look up all these codes?
Iat Sensor 1 Circuit High Input
O2S Circuit Insufficient Activity Bank 1 Sensor 2
O2S Circuit High Voltage Bank 2 Sensor 1
O2S Circuit Insufficient Activity Bank 2 Sensor 2
muti-cyl. misfire
Secondary Air Injection (AIR) Solenoid Control Circuit Bank 1
also the wires brk a while ago that were hooked to the IAT sensor and i soldered them back up im not sure if they are making a fine connection with the solder.
