85mm Air Lid
Old Sep 26, 2006 | 10:15 AM
supersix's Avatar
Default 85mm Air Lid
Does anyone know where to get an 85mm air lid????? I tried texas speed but they have discontinued them....
Old Sep 28, 2006 | 11:16 AM
Ls1CamaroGuy87's Avatar
unless you have a 90/90 mm setup, then its not going to do anything
Old Sep 28, 2006 | 12:43 PM
TheBlurLS1's Avatar
That's what she said...
LG's is pretty big from what I understand. The ID of the regular sized manifolds is around 85mm. An 85mm MAF uses a coupler to attach to it instead of slipping inside like the stocker.
Old Sep 28, 2006 | 12:47 PM
J02ws6transam's Avatar
yeah i have the same problem. i am building a 455 ci ls1 and i have the 90/90 setup and am wondering what to do for the intake. i wish i could still get the 85mm intake. i was looking at the lg on and it says that the id on the intake is 3.5 inches. would that equate to 85mm or is there another company out there that makes a 85mm or equal or is my best bet to buy the lg intake. thanks for the help
Jon
Old Sep 28, 2006 | 12:51 PM
TheBlurLS1's Avatar
I would just use the one you have now, and buy a coupler for it. Stock style lid, coupler, 85mm z06/truck (descreened) MAF, another coupler, into 90mm TB.
Hightempsilicone.com and Intakehoses.com have some cool stuff.
Old Sep 28, 2006 | 12:52 PM
chris93266's Avatar
3.5" is about 77mm
Old Sep 28, 2006 | 12:56 PM
chris93266- thanks for that info. yeah idk what to do yet, i have a slp lid that i had with my old setup, and i just bought the slp 85mm mas air, then the smooth bellow and the fast 90 w/ nw 90 throttle body. who would sell the coupler if i kept the slp lid, or any else have a good suggestion on what to do? thanks for the help
Jon
Old Sep 28, 2006 | 01:39 PM
chris93266's Avatar
just for reference 1"= ~2.54cm
Old Sep 29, 2006 | 04:26 PM
any more info out there?
Old Sep 29, 2006 | 04:46 PM
WS6 Rampage's Avatar
From: The dirty taint of the country. ...Los Angeles
Check with SLP. I use a 85mm MAF with their airlid!
Old Oct 1, 2006 | 07:32 PM
redtail2426's Avatar
i just measured the inside diameter of my whisper lid and it was 90.5mm,then i measured the stock lid and it was like 89mm almost 90..So if you go speed density setup with a fast 90/90 combo then any lid should work just fine as the inside diameter will be the same size as your throttle body and manifold.
Old Oct 31, 2006 | 06:30 PM
hotrodrx7's Avatar
What is the part number for the GM 85mm MAF?
