Does your car stink? How about burn your eyes? No cat, tuned car...
Originally Posted by Dal1as
Weird, my car exhaust doesn't smell at all.
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
haha...well that makes me feel better about my cam. Must be a good one since my car stinks like a ****!! hehe. So the fuel smell is mostly due to the cam specs? No way to tune it to smell any better? I mean...Im not going to go to rapid and say..Please tune my car so it doesnt stink.. Im just curious.
If the sound doesnt warn the slow people that its not an everyday thirdgen...the smell sure will !! haha.
Justin
Justin
Originally Posted by Gauge
My car smells so strongly that I can't let it idle in the garage or the entire house will start to smell. It will burn your eyes and suffocate you. If you walk behind my car while it is running, your clothes will need to be washed because you'll smell like gas the rest of the day.
![Lurk](https://ls1tech.com/forums/images/smilies3/lurk.gif)
Originally Posted by jmm98LS1
If you'll notice, most of us that have "stinkin' cars" have a bigger cam...the overlap at idle dumps a little raw fuel into the exhaust making the much stronger smell.
doesnt the cam add to most of the smell? Seeing as though with a cam you have more unburned fumes? Or am I wrong. My friends T/A didnt stink till he got his new cam and now I refuse to drive behind him.
It is like someone stated before - the valve overlap causes most of it as it scavenges the exhaust out and may take some fuel with it.
I have a cam somewhere around 238/242 .614/.623 on a 112* and it smells pretty damn bad. We had to up the fuel on idle though to keep the pig running. My centermount tips are black and much like someone else said, walk behind the car and you'll smell like exhaust for the rest of the day
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
11Second Club
Originally Posted by dailydriver
Could (or does) this also cause flames to shoot out the exhaust when you back off suddenly at high revs (especially with dumped TDs)?? Or would that take a cam way too radical to even idle, or be streetable??
#32
Originally Posted by RedWS6 00
I have no cats either, when sitting in traffic running 15.8 AFR at idle, it seems to give me a headache. So I'm not running rich, and it still smells, its only since i removed the cats though and tuned for lean idle.
i found if idle is richened up the smell goes away, not completely but definitely noticeable....i believe the smell is caused by an incomplete combustion cycle, to little fill air not enough gas...unfortunatly after a car is tuned the PCM will command a ratio of 14.6:1 in closed loop, to get a reduction in smell, idle needs to be around 13.8:1 or so.....my .02
#34
Originally Posted by orangeapeel
Burn your eyes? Try running some 108 leaded VP C12 and then come talk to me.
How about 100% methanol for a good eye-burning experience
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
The previous guys are right, the aggressive overlap cams produce the "stink". I did the stock cam to F13 back to stock; no stink with the stock cams.
#37
Mine stinks, in closed spaces. I run a lean idle due to the 10* overlap. But hey, that's where it likes it. No idle, surging or other part throttle issues whatsoever. Unfortunately, smooth running and non-smelling don't always go hand-in-hand.
Perhaps some people shouldn't spend so much time snorting exhaust fumes and just drive the sucker...
#39
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
I love it.
I love it.
#40
Tech Resident
i don't think anyone else has mentioned this, but what you are smelling probably isn't gas. the magnaflow catback is stainless steel. stainless steel tends to smell really bad the first few times it is heated. it has a coating on it that must burn off and may take a few days and maybe 100 miles to do it. i can vouch for this first hand as my car suddenly smelled bad as soon as my stainless cutout was put on, but went away completely 50 miles later.
what you're smelling is likely the newly installed magnaflow catback, not gas from the ORY. the gas fumes aren't enough to burn your eyes with an ORY, unless you're idling in your garage with the door closed like tom from office space...but he was trying to kill himself because he got laid off.
