Best fitting LT?
Old Sep 28, 2006 | 08:20 PM
Ironxcross's Avatar
Default Best fitting LT?
What is the best fitting LT you guys have had experience with that was also somewhat affordable and didn't rust out in a year or two?
Old Sep 28, 2006 | 09:31 PM
Luna's Avatar
Best fitting headers that won't hurt the wallet and will last (although not as long as stainless) are going to be coated pacesetters. period.
Old Sep 28, 2006 | 09:46 PM
smokin t/a 600's Avatar
+1 for coated pacesetters
Old Sep 28, 2006 | 11:12 PM
staringback05's Avatar
+2 pacesetters
Old Sep 28, 2006 | 11:30 PM
BatmobileSS's Avatar
+3 Pacesetters
Old Sep 28, 2006 | 11:41 PM
DRTY LS1's Avatar
I have hooker lt's and they fit perfectly went in fairly easy and no rubbing of any kind. Altogether with the y-pipe and the headers being jet-hot coated they ran me $888 on the nuts!
Old Sep 28, 2006 | 11:50 PM
WS6 Rampage's Avatar
From: The dirty taint of the country. ...Los Angeles
Can't you order a coated version from them for like a buck fifty more?
Old Sep 29, 2006 | 12:05 PM
Luna's Avatar
Yes, they do offer a coated version, although I'm not sure how much more, IMO you are wasting you're money buying uncoated.
 Michael S. Palmer
Old Sep 29, 2006 | 12:09 PM
slowscott's Avatar
Originally Posted by DanO
Everyone will say Kooks or QTP.
However, there are always bad stories for each.
I have Kooks, they fit HORRIBLE, and needless to say, i have gone back and forth many times and they tell me that they fit fine... (if you like it bouncing off your K-member)
But on another note, every company will have good parts and bad parts. This is because the quality control on aftermarket parts as a whole is quite poor. Going with Kooks or QTP may reduce your chances of having bad parts, but wont eliminate it.
Sounds like you need poly motor mounts. I have almost zero clearance between my K and QTP's, yet no banging.
adillhoff's Avatar
Maybe if you live up North. There are far less rust issues in the south due to the climate and altitude.
Old Sep 29, 2006 | 12:10 PM
ryanfx's Avatar
+4 for coated pacesetters. When I put mine in my jaw dropped how well and fast they went in.
Old Sep 29, 2006 | 02:06 PM
Ironxcross's Avatar
are poly motor mounts required for the headers/y-pipe not to slam around in the car?
Old Sep 30, 2006 | 06:40 PM
slowscott's Avatar
I did my poly mounts when I did my headers and duals so I can't compare before and after. However, based on how much less the engine torques and how tight the header/exhaust clearance is, I would say they are a requirement.
Old Sep 30, 2006 | 08:25 PM
skifast87's Avatar
idk i bet you could get away with it
Old Sep 30, 2006 | 09:05 PM
chris2000ss's Avatar
my hooker LT'S fit pretty darn good and i'm very happy with them..
Old Sep 30, 2006 | 10:58 PM
Luna's Avatar
If you are doing headers JUST DO POLY MOUNTS AT THE SAME TIME!
They are inexpensive, will help to prevent any exhaust banging and just generally make the car feel tighter. If you ever decide you want poly motor mounts after you put you're headers on you will be kicking yourself!
Here is a badass writeup written by me
https://ls1tech.com/forums/generation-iii-external-engine/492703-best-poly-motor-mount-write-up-ever-written.html
Old Sep 30, 2006 | 11:02 PM
Evans752's Avatar
Im going to fote FLP (Finish Line Performance). Looks like the same thing as the Dinatechs though.
Old Sep 30, 2006 | 11:18 PM
SIC LSX's Avatar
pacesetter coated!
Old Oct 1, 2006 | 12:04 AM
SweeTbone's Avatar
Kooks. No poly motor mounts here and no banging of anything whatsoever. No hitting the K-member and no Y hitting the floor.
