TSP TD ground clearence
Old Sep 30, 2006 | 04:49 PM
SS4Luck's Avatar
Default TSP TD ground clearence
So i know TD's are ground clearance friendly so keep that in mind as i ask this question...
how good the the ground clearence with TSP Td's?
my car isnt lowered and probably never will be i just wanna know if im going to be scraping for everything, the only exhuast shop around here that will do cutsom td's for me wants 700 bucks and i just cant pay that....
thanks
Old Sep 30, 2006 | 04:59 PM
Phoenix 5.7's Avatar
mine has pretty good ground clearance. if u put the x pipe correctly and hang the hangers high enough, u have plenty. i hardly ever scrape, and then its nothin major. it is loud. if u do go duals, i would look into gettin it extended out the back under the axle
Old Sep 30, 2006 | 05:02 PM
jrp's Avatar
jrp
SN95 Director
lets just say removing mine was the best decision i ever made...
Old Sep 30, 2006 | 05:08 PM
speed_demon24's Avatar
I have the TSP true duals and had an exhaust shop put them on and weld everything up. They also ran it out the back under the axle, 3" all the way, and 6 months later I'm still waiting to scrape them for the 1st time. They can have shitty clearance, or good clearance, its up to the installer. My x-pipe is tucked up better than my y-pipe was.
Heres a link to clearance pics
https://ls1tech.com/forums/showpost....6&postcount=20
Old Sep 30, 2006 | 06:40 PM
GET_SOM's Avatar
demon, is your car lowered at all?
Old Sep 30, 2006 | 07:24 PM
stock height
Old Sep 30, 2006 | 07:27 PM
GET_SOM's Avatar
thats what i thought, thanks.. i was just curious
Old Sep 30, 2006 | 08:16 PM
cws T/A's Avatar
Cant make mine scrape
Old Sep 30, 2006 | 11:08 PM
rmsurfer212's Avatar
how much did the shop charge you to install the tsp x pipe and the extension under the axle?
Old Oct 1, 2006 | 12:31 AM
$300, well worth it, they did a top notch job.
Old Oct 1, 2006 | 01:21 AM
Shallow Bay's Avatar
Wow, that’s some amazing ground clearance. What kind of headers do you have?
