WOW march performance your #1 here's to you.....rant.....
SiL3NtXWS6 + ArcticZ28 - Thanks i tried my modded pulley puller today with no success. The only thing i did do with success was mess up a the first couple threads in the crankshaft. The damn pulley didn't budge at all either haha go figure . So tomorrow or this week i will find a 3 jaw large enough i hope get the damn thing off and finish my cam swap. I feel like tossing the SOB out into the street after i get it off.
Is this 3 jaw gonna be big enough it says 3,4,5,8 inch pullers
http://www.northerntool.com/webapp/w...70_13315_13315
I wanna make sure before i buy this thing.
Originally Posted by ArcticZ28
8" SHOULD do the trick and let you grab the back lip.
You can always buy some extenders for the puller as well. I'm not exactly sure what they are called but they are little flat pieces of steel with a bolt hole on each end that bolt to where the arm would normally bolt to and then you can attach the arm at the end of the piece of steel, thus giving you some added length.
That's what she said...
I think Sears has some big *** ones IIRC. I didn't bother reading the aforementioned immature posts, so keep them at a minimum.
89stang - Sorry you're having problems, I know EXACTLY what it's like to be pissed. The title of this thread comes off as a bit childish, but as I said, I know what it's like to be pissed.
You might also try a little heat, you'd be suprised at how much it will do. I had pounded on a slip fit exhaust connection for 20 minutes with no results, then I grabbed the torch. Few whacks and it fell off.
ArcticZ28- Yeah i saw you could buy different jaw peices, I'm going to snap on later after i get off work i didn't know there was one about a half hour from me.
The Blur- True my title might be alittle childish but i also meant it to be kinda humorous. I shoulda worded it different but what's done is done lol. And our sears here sucks, i'm sure they could order what i need but without seeing how big the puller is in person my luck it would be the wrong one.
And your right about some heat, i've got a heat gun i'm going to use on it later today also. I figured it would be tough to get off it was tough to get the pulley on. I just hope it comes off without damaging the crankshaft.
brad- i would advise a different pulley
Agreed, Im in the market for a new pulley. Im glad I saw this. It sucks that another persons pain can save other people from future problems. I ran into that about a month ago. I was backing my ARP crankbolt out and it siezed up. Not my fault at all (so I found out later) but I was pissed none the less. Hope the rest of the install goes well though. Good Luck
#32
Originally Posted by NOBR8KSS
Let us know when you get it off and what kind of pulley you wound up using so that the next person with this problem will have a little help. Good Luck.
Update on the puller though i found a HUGE puller i borrowed from work it "should" do the job lol.
#33
Once again this is the type of situation that occurs when people do not read about a product & just go buy it. I don't know how many time I have told people to research the product & make sure it exactly right for them before purchasing.
Just b/c you have to use a bigger puller does not mean there is something wrong with the pulley. It just means you don't got the right tool & didn't do your research. No one to be mad at but yourself in this one.
#35
#36
And yes it does mean there is something wrong with the pulley it's a poor design on march's part for making it and not offering a puller for it. There maybe alot of places around you or Arctic or someone else that sells the puller i need, like i said before there is no place in a 20-25mile radius of me that offers a puller the size i need. And in the time frame i had to work on the car i didn't want to order it off the internet (last weekend) plus what if i recieve it and it's something i already tried. Thanks though i'm glad you were here to offer some the input. on nothing
Oh and the puller i got from work is to damn big it would work if i had enough room.
#37
Oh and the puller i got from work is to damn big it would work if i had enough room.[/QUOTE]
I don't have a march pulley but I have to pull the radiator to get my puller in there. You may have to go that route.
#38
#39
I already have everything apart ready for the cam swap so the rad. and everything aren't in the way. This set of 3 jaws is HUGE lol, it's a set of posi-lock pullers 10" ones.
#40
Originally Posted by 89tang
Wow do you guys not read or what? Like Arctic said no where did i EVER read the march pulley was this hard to get off before i bought it. It's not because i have to use a bigger puller IT'S BECAUSE I CAN'T FIND A BIGGER PULLER. If you would read the whole thread you would know that already obviously. The pulley was exactly right for me according to all the praises it got from ppl. that had/were using it at the time.
