How in the HELL does my 02 have EGR
Per JRPs FAQ Sticky
933 97 aluminum perimeter bolt 5.7
806 97-98 aluminum perimeter bolt 5.7
853 99-00 aluminum center bolt 5.7
241 01-03 aluminum center bolt 5.7 (some late MY00 cars got 241 castings)
243 LS6 aluminum center bolt 5.7
98 Has COMPLETELY different heads than 99+ they are perimeter bolt whereas all the others are center bolt valve covers.
So if you have 806 heads you know what year LS1 you have. But if thats the case I'm fairly certain it would require a 98 PCM. (I'm not sure if they are backwards compatible but I know 98's have completely different PCM's)
there is also a sticker under the hood that says "this vehicle complies to the emissions standards for the year blah blah"
its very possible that someone had a built motor in the car and when it was time to sell it they swapped out the motor for a 2000 complete with harness.
also, your heads should say 241 (late 00-04 LS1 heads) on the passanger side. if they dont have a number over there, but have 843 on the drivers side it is a 98-early00 motor.
So I was looking at the emmision sticker under the hood. It shows a diagram of the cats and the air system but it does not show the egr. The door and dash vin #'s are the same. Where are the casting #'s on the head? The front of the passenger head is blank. The valve cover are center bolts with coil packs on a rail. I understand demodding a car but to change the wiring harness seems like a waste of time. Where exactly are the vin numbers stamped? Thanks for all the help everybody.
Will
some numb nut blew the motor... found a complete motor somewhere from an older vehicle, like 00 or 99... swapped the motor in.. called it a day.
it's all clean on there, but of course - stuff can 'easily' get left out of those things.
if you want a copy man, just send me a PM
- Ron
my friend had a totaled car and it never showed up as being totaled. if you dont belive me pm me and ill give you the vin to my totaled car, it wont come up as being in an accident, and it has a 100% clear title on it even though its 2 feet shorter in the front
good luck
Will
Silver02TA thanks for checking the carfax. Good to know it was clean.
Will
Well that really sucks. There really isn't anything wrong with the older LS1s; the only thing that you should be concerned about is not knowing how many actual miles are on the engine. Now, if you payed a pretty penny for that car because the odometer had low miles, and all you got was a 02 car with a motor with...let's say 150K miles, you'd have a case against the dealer that sold you that car. So tell us, how many miles are on the odometer?
Don't beat yourself up about not knowing this when you bought the car. It's just because of the stuff I have learned in the past 2 years about these cars that I knew something was not right with it. Otherwise I would not have seem anything wrong either.
The '01-02 engines are better. Besides the intake, they have better heads, rodbolts, oil pump. Dont let the dealership push you around. It would be much cheaper for them to give you your money back than to deal with the law.
