How in the HELL does my 02 have EGR
Intake
Here is the plug in the wiring harness for the egr pump
And here is the exhaust manifold with both fittings and and the egr pump.
2G1FP22G622141211 vin
Failing that. If it is indeed EGR then logicaly it leaves only a few possibilities:
1. An oddball car from GM using up old parts (probably unlikely, unless it was one of the last 02's and they wanted to get rid of parts lying about the factory).
2. Your car is a ringer with a false ID.
I doubt very much someone would swap in an ealier engine and change the loom. It would be more work than its worth.
Don't thnk I've ever seen an '01-02 with EGR (my manifolds both intake and exhaust look EXACTLY like that and I have an '00). Wierd...-J
