swappable parts? LT1 to LS1
Old Oct 8, 2006 | 05:07 PM
Lythropus's Avatar
Default swappable parts? LT1 to LS1
Will the a/c compressor, driveshaft and rear end swap form an lt1 v8 to an ls1 v8 car? I know I will loose traction control but what about abs? Are the connectors the same?
Old Oct 8, 2006 | 06:48 PM
00454sscamaro's Avatar
driveshaft will, dont know about the others.
Old Oct 8, 2006 | 06:54 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Not alot. The LT1 is more like the SBC. I think that you will find everything is different under the hood.
Old Oct 8, 2006 | 09:34 PM
phoenix305's Avatar
the rear end and drive shaft will for sure. don't know about the a/c compressor.should be able to retain abs.
Old Oct 8, 2006 | 11:04 PM
Full-Force's Avatar
negative on the a/c compressor
forget about anything on the motor swapping over
Old Oct 8, 2006 | 11:31 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
If you want an LS1....get one.
Old Oct 9, 2006 | 12:13 AM
~JOSHUA's Avatar
A motor swap like that is futile with the current f-body prices. Hell if you can handle a $275 for 4 years you can get a sweet LS1 car.
I own both an LT1 and LS1 f body and all the engine stuff is different.
Sure it "can" be done, but anyone who knows really wouldn't bother.
Old Oct 9, 2006 | 01:22 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
It turns into a nightmare really fast.
Old Oct 10, 2006 | 08:28 PM
Lythropus's Avatar
Thanks for the help but who said I was doing a swap? I own two ls1's but my a/c compressor recently went out and my friend has a broke down lt1 in his back yard with a perfectly good compressor. To bad it won't fit. Thanks for the other info though, guess I'll be loosing TCS
edit: I just read my post. I guess it was a little decieving, sorry about that.
Old Oct 11, 2006 | 07:12 AM
jay_99z's Avatar
Rear end will bolt up just fine but the brake swill have to be swapped along with it.
