NLP Billet PCV Catch Can, $74.95
Originally Posted by Bill Bowling
I have the other brand PCV Can and it has a drain but I always take it off to drain. It would be a mess if I did not.
Bill![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
Bill
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by bowtierodder
whats the purpose of a catch can?
It catches oil from the pcv system , the line from the pcv tube goes into the catchcan . Then run a hose from the catchcan back to the intake manifold. Without one under WOT you could be getting oil inside your intake manifold CAUSING PRE DETONATION
![Bomb](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bomb.gif)
#34
Is the bracket attached, or can I flip it and put it on the driver's side the same way?
#37
I appreciate ZoomZ posting info as we go along here as I am still out of town till Monday. I also appreciate the "tech" info other folks are giving for those that are asking how this works. Great community as we all know.
I am working on an install sheet and will most likely put in about 2 feet of 3/8" hose and a brass barbed 3/8" connector for folks to help with the install. For the 2004 and up C5, C6 and GTO applications I will include a 2 brass barbed 3/8" connectors since there is no PCV valve.
Thanks again and we are working on a lot of colors and working on quotes now.
Mike Norris
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
Mike Norris
#39
I am going ot be mounting mine to the the top side bolt in on the passenger side of the head on my T/A. I will have no clearence issues, just need to go get the dam tubing. It is going to look great in there.
#40
Originally Posted by BlackHawk131
Yea it looks as though you copied AMW! But your doesn't have the rings cut on the inside to keep the oil from crawling back up the walls.
