NLP Billet PCV Catch Can, $74.95
#142
Mike a very nice piece there. Mine came in yesterday. I think the only thing that would be an improvement would be to include the bolt size to thread into an LS head. Right now I am trying to find that info so I can stop at Lowes and get one on the way home from work.
#144
If high rpm blasts dont spew oil out of that oil cap breather ide say your good to go .
My Harland Sharps rocker arms will throw oil out of those type breathers and right down on the headers :/
#145
This is the way mine is set up and I never have any problems with the breather..I rinse it out about once a month with brake clean and a compressed air blow dry ... Oooops the photos would not post up... .. you'll have to use your imigination ... LS6 valley cover w/LS6 PVC, GMPP cast aluminum CHEVROLET/ bowtie logo valve covers with no provisions for PVC..and a K&N breather in the oil fill hole..works great .. I was going to use this catch can and breather if the set I am using now didn't work..
#147
I did notice a little oil today... But not much. I think im going to delete even the catch can set up, its still sucking oil right through it.
The bright side,with the breather the car seems to run much better.
#148
Restricted User
Make sure you don't have the pcv backwards or you will cause pressure to build up. If you are not sure, put a straight hose on temp to see if that helps. The can will not be the problem.
#153
why have i seen some hooked to the throttle body? is this right? i need some installation pics, so i can see how to do mine. also i need to know all the parts i am going to need. thanks
#154
I just checked my catch can after about 3-4k miles and I have about a half of a shot glass in there at most. I also put in a new pcv valve i nat the same time.
My intake is dry .
