Ls7 Intake?
Old Oct 12, 2006 | 01:11 PM
02BEAST's Avatar
Default Ls7 Intake?
Anyone heard of it and how much of a gain over the LS6 Intake I currently have?
Old Oct 12, 2006 | 01:20 PM
GR33N GoblinM6's Avatar
ok.. you really need to SEARCH!!! and 2nd.. head over to the LS2-LS7 board.
.. you cant use the LS7 intake with LS1 or LS2 heads.. the LS7 intake runner ports are different and wont work..
thank you, drive through
Old Oct 12, 2006 | 01:23 PM
JCurtin's Avatar
what a dick dude. Did you really need to say all of that? I get everyone flipping about people not searching, the rest was just un needed.
Old Oct 12, 2006 | 02:43 PM
john563's Avatar
02beast
your fine with the intake you got if you do heads and cam then try to save for a fast 90/90set up
Old Oct 12, 2006 | 02:54 PM
Quickin's Avatar
Search is bullshit. You usually never find exactly what you're looking for and if you do it takes all ****** day.
Old Oct 12, 2006 | 02:58 PM
SSmokin99's Avatar
+1....I don't understand why people have to act like a dick about it...
Old Oct 12, 2006 | 03:20 PM
Ls1Won's Avatar
The search is down and I agree don't be a dick about it....
Old Oct 12, 2006 | 04:21 PM
ProjectCamaro's Avatar
Honestly, lighten up. The search doesn't even work that much at all anymore.
Old Oct 12, 2006 | 04:30 PM
Quickin's Avatar
There's a good thread from Jeremy Formato about his gains with these two intakes, he does port them and I think most of his data includes ported intakes. But I can't find the fuggin thing because the damn search doesn't work.
IIRC...he was getting 14-17 RWHP gains from his ported LS7 intake over a ported LS6 intake. NOT 100% sure though, just from memory.
Old Oct 12, 2006 | 04:49 PM
FBodyPerformer's Avatar
skipping past your rude remarks, but at least youre knowledgable.
Will LS7 heads work on a LS1/LS2 block so that you can run a LS7 intake? Would it be worth it?
Old Oct 12, 2006 | 06:10 PM
Coy's Avatar
Coy
Dick.
Old Oct 12, 2006 | 06:38 PM
transamfreak01's Avatar
yeah dont worry about these guys on here. i would go with a fast 90/90 set up. hey Coy whos that girl??? haha
Old Oct 12, 2006 | 06:45 PM
02gixxersix's Avatar
People do it on every forum about anything on the web. The thing is the only way it annoys me is if the answer is a few threads down on the front page. After that if you don't want to answer don't post IMO.
Old Oct 12, 2006 | 11:15 PM
01 BERGER CAMARO SS's Avatar
F'in rude bro. I thought this forum was so that members could share their knowledge not to be a dick when some one is looking for help. BTW the search dont work half the time.
Old Oct 12, 2006 | 11:57 PM
SSmokin99's Avatar
++++111111111111111111
Old Oct 13, 2006 | 09:45 AM
quit whining girls.. just because I told the guy to search makes me rude? right.. and i spent all of 3 minutes running a search and came up with 4 threads related to this..
I didnt swear, or call names, or anything else.. just told him to search.. then gave him the info..
and I love the people that just came in to say "dick" "Rude" .. what are you contributiting? nothing.. at least i gave him the answer.. so I could have been nicer.. who cares.. I didnt know you guys were all sensative.. you GUYS(i use that term loosely) sound like a bunch of people that traded in their F-body's for volkswagon vans with flowers..
Old Oct 13, 2006 | 09:52 AM
Quickin's Avatar
yes
yes
OH YES!
ZL1Killa's Avatar
search has worked for me. if i don't find it in 10 mins though, i post
i saved for a Nick williams 90mm TB and FAST 90mm intake
Old Oct 13, 2006 | 09:59 AM
LS7 heads will bolt on to an LS1 block.. BUT.. you need to have the block resleaved.. the 3.898 bore is too small for the LS7 heads.. i believe the minimum bore size to use LS7 heads is 4.100 (LS7 being 4.125)
See this thread over here LS7 Head compatibility
So any way you look at it.. you're going to need to pull the engine, tear it down, resleeve, new pistons rings ect. Starts getting expensive.. the sleeving alone will be around 2500$.. LS7 heads are not cheap.. LS7 intake is about 400$+ retail... also you need a conversion to run your stock throttle body since the new LS7 (90mm) uses 4 bolt mounting instead of 3 bolt
See this thread about the throttle body LS7 90mm with cable
there is a guy on this board who has done conversion this with great results.. I believe the thread on this is still showing over in the LS2-LS7 board..
is this nice enough?? or should dot all my "I"'s with little hearts for the rest of you guys?
Old Oct 27, 2006 | 06:25 PM
Havok2's Avatar
shut it. now you wanna act sensitive?
