Top end power loss after headers
Old Oct 15, 2006 | 09:54 PM
brad8266's Avatar
14.7:1 is the stock stoich set in the PCM, once the car warms up and goes into closed loop the PCM will strive to stay at 14.7:1 at idle and part throttle operation. The PCM relies on the oxygen sensors for feedback on how the AFR is doing. The signal off a oxygen sensor is a sine wave, the sensors are always switching up and then down, which represents rich and lean. The average of the wave is the AFR. What happens is the sensor will pick up a lean conditon then the PCM will add some extra fuel, then it will read rich and then the PCM will pull some fuel. This is a continious operation that happens many times per second. The adding or pulling of extra fuels what is known as fuel trims, which are the PCM's fueling learning ability. As long as the O2 sensors are working properly the AFR will be 14.7:1. Cold start and WOT are different stories because in both of those conditions you are in open loop, which does not rely on any feedback for AFR correction.
Search around in the tuning forum for more information, there is a ton of it.
Old Oct 15, 2006 | 10:29 PM
BrandonDrecksage's Avatar
Originally Posted by LSGunZ28
I do have an idea on how it operates. and I may not know as much as you maybe. But I have learned that 14.7:1 isnt really the A/f ratio cars generally operate at. That is just a ballpark number, just like how a 4 stroke cycle is: intake, compression, ignition, exhaust. But we all know it isnt that simple. a spark doesnt occur the whole time of the igntion cycle. just like overlap occurs and exhuast and intake cycle overlap with each other( just an example) and all those things. it isnt quite as simple. the A/f changes as TP changes as does load on the car, etc.
I am pretty certain of that.
But please put some input on my misinformation if you can, so that I can learn.
thanks.
13 to 1 is waht a car averages around when going WOT. Gas needs 14 to 1 to ignite, but when the engine is under load, you want to be runnign a little richer because of varibles in the air..ect. i.e. 13 to 1 in a n/a car and a lil below that in a f.i. car.
Old Oct 16, 2006 | 12:16 AM
LSGunZ28's Avatar
I knew all that. But what I didnt know is that the stoich is set at 14.7 :1 even though that is the rating of AFR. However I am not entirely sure that when it goes to closed loop, it is doing precisely 14.7 : 1, what about higher elevations, less oxygen , but MAF cant tell that. so how will the AFR be 14.7:1? etc... That is why I dont hink it stays at 14.7 : 1 not even at 10% throttle.
Old Oct 16, 2006 | 08:28 AM
So how does your computer know when your going wot throttle in higher elevation that the air is thinner? The senors tell it, just like normal driving. it reads what is hitting the o2 sensors..ect and adjusts to get as near to 14.7 to 1 as possible. Have you even seen a dyno graph? Notice that at the very beginning..sometimes the engine is really lean? in the 14s..sometimes higher? Its because the dyno operator starts to sample before going wot. ALso, why do you think part throttle and idle tuning are different then wot. If the desired a/f was the same, they wouldn't have to do wot throttle tuning..then could jsut tune your idle and part throttle tuning.
Old Oct 16, 2006 | 11:25 AM
brad8266's Avatar
What do you mean by 14.7 is the rating of AFR, that doesnt make sense.
And yes it will always do precisely 14.7:1 even at high elevations because the oxygen sensors will always be able to read the AFR accurately and will report the status back to the PCM which will in turn adjust fueling to stay at 14.7:1. The MAF has nothing to do with it. The MAF provides the PCM wilth the baseline fueling and the oxygen sensors provide for realtime fueling adjustments on the fly, which are fuel trims. The elevation and other environmental factors dont matter because the oxygen sensors can always measure the amount of oxygen in the exhaust accurately and report it back to the PCM.
If you dont believe it go buy yourself a good wideband sensor and do some logging, you will see that on average it will stay at 14.7:1 at all times, it will fluctuate up and down for quick moments up to like 15.1 or down to like 14.2 but will stablize out at 14.7:1 everytime as long as you are in closed loop.
Old Oct 18, 2006 | 01:36 AM
LSGunZ28's Avatar
I see. and by rating I mean that is the optimum AFR for a car, but not by performance standards.
Old Oct 18, 2006 | 11:09 AM
brad8266's Avatar
Right the PCM will stay at 14.7 in closed loop to maximize fuel economy. When you floor it though it goes into power enrichment mode where it will add a specified amount of fuel to compensate for the extra fuel needed for maximum performance. Tuning the PE table is one of the important parts in tuning your car for WOT performance.
Old Oct 18, 2006 | 11:53 AM
Wheeler99WS6's Avatar
Brad definitely knows his ****! I always take the time to read a thread he has subscribed to. He knows more about fuel trims alone then I know about everything I think. I am definitely interested in what this dude has to say, I am trying to learn as much as I can from him while he is still on the board, hoping it will make me a better owner of the infamous FBod
Old Oct 18, 2006 | 11:56 AM
brad8266's Avatar
Thanks, although i dont claim know too much about all subjects, I do think that I have a good understanding of the PCM, the sensors, and how they interact with each other. It took me a good while to learn all of it.
Believe me though there are plenty of instances here where I had to put my foot in my mouth after the fact.
Old Oct 18, 2006 | 12:19 PM
bjamick's Avatar
Originally Posted by DuronClocker
You're a brave soul to be running a 100-shot on a car with an aftermarket MAF untuned.
mine is a wet shot to not dry
Old Oct 18, 2006 | 12:24 PM
brad8266's Avatar
The the risk isnt as bad then. Dry with an aftermarket MAF is not good.
Old Oct 18, 2006 | 12:37 PM
  #32
bjamick's Avatar
ya so i have nothing to do with the maf, my fuel get sprayed in at the same time the N2O does so its all good but i still have to get it tuned bad. when i get the tranny done im going to have it dynoed and tuned with my HPtuners.
Old Oct 18, 2006 | 03:05 PM
  #33
sdbrown84's Avatar
All in your tune. Headers will do nothing more than HELP your Top end, that is what they are made for.
Old Oct 18, 2006 | 03:14 PM
  #34
brad8266's Avatar
Old Oct 18, 2006 | 04:14 PM
  #35
multiplicityZ's Avatar
i replaced my stock manifoldsand y-pipe with coated pacesetters and a TSP ORY pipe and i lost 1/2 MPH in the 1/4 mile and my E.T. was the same.
this seems odd to me because i feel a slight difference on the street.
regardless that i am running a flowmaster 80 i should have picked up a lil MPH at the track. i know i will pick up a lil if i ditch the flowmaster though.
any thoughts why this might be?
Old Oct 18, 2006 | 04:16 PM
  #36
brad8266's Avatar
You may need to tune your PCM. You could also now be experienceing false knock, which is common with headers and a ORY.
Old Oct 18, 2006 | 04:24 PM
  #37
was it different weather? did you have the car tuned? some run a lot mroe rich after the headers basically makign any gain dissappear.
Old Oct 18, 2006 | 04:47 PM
  #38
get a tune and the false knock will hopefully disappear?
and the weather was within 3 or 4* between the swap, a weekend apart.
but the car is not tuned, and i read earlier that having no egr/air and not getting it tuned out yet might have caused a problem too, besides the annoying SES light.
could an 02 sensor have taken a dump on me and be causing me some problems?
Old Oct 20, 2006 | 03:54 AM
  #39
LSGunZ28's Avatar
Thats weird. Cuz I went from
8.33 @ 86.6 mph to 8.07 @ 89.25 mph with the same headers and Y pipe as you, the difference is I had a SLP Lm for a catback
Oh and I ran Nittos on both runs and launched it at 3700 RPM @ 12 psi Tire pressure vs 3100 RPM @ 15 psi tire pressure.
Old Oct 20, 2006 | 03:56 AM
  #40
LSGunZ28's Avatar
Gas needs 14 : 1 to ignite.... then how did chrysler get away with their lean burn cars in the 80s. I know there were really bad, and knocked a whole lot. but how did the gas ignite?
