Top end power loss after headers
Old Oct 13, 2006 | 11:20 AM
BlackTAWS6's Avatar
Question Top end power loss after headers
Okay, so I recently installed some pacesetters lt's on my 99 TA. I got rid of the AIR and EGR did plugs and wires. I'm running with no cats a cut out after the 3in Y. I have a friend with an 04 Mach 1 and when we used to race from a 30 roll he would pull me by a bumber and once we hit about 60 I would walk right by him...Now after headers from a 30 roll I pull him by a bumper and it stays that way...no top end pull!!! Someone please tell me whats goin on?! I have a MAFT BTW...
Old Oct 13, 2006 | 12:30 PM
Rob98LS1's Avatar
sounds like your car needs a tune. Reason I say that is because you deleted AIR and EGR, and without getting the ecm tuned for that, usually it will make the gains less signifacant than expected. Even with just exhaust/mild intake mods its a very good idea to tune.
Old Oct 13, 2006 | 03:57 PM
bjamick's Avatar
yep my car kinda has this problem but i havent ever had my car tuned and ive got mods in sig LOL
Old Oct 13, 2006 | 05:01 PM
BrandonDrecksage's Avatar
whats a maft? Did you change anything else? also..toher than racing your mach 1 friend..do you have any numbers. he could have gotten better at driving, you car can be running to rich or to lean on the top end killing power..you could have gotten crappier at driving...ect..to many varibles. i'd bring it to the strip and see how it does comapred to soem base numbers.
Old Oct 13, 2006 | 05:06 PM
brad8266's Avatar
Mass Air Flow Translator.
You should start by taking that MAFT off the car, then se how it runs. What may have happened is that since you installed the exhaust it might be too lean which may be causing knock retard, which will kill power. get rif of the MAFT first and go from there.
Old Oct 13, 2006 | 05:07 PM
brad8266's Avatar
When I installed Long Tubes it pulled crazy hard up top even on the first drive with them on before the PCM even learned the new trims.
Old Oct 13, 2006 | 05:18 PM
02blackta's Avatar
i would have to say that your running rich..... ( can you smell gas at all while your car is at idal).... that is what my car did after the LT install.... i would go with the edit tune or the SCT tuner if you know anyone that can read the graphs..... it will help you out with your top end but not fully.... thats just something you give with you go with LT but they help out your low end... and if your racing a stang thats what you need ...... do a few more mods with your top end and he wont stand a chance..... i have a friend with a mach as well
Old Oct 13, 2006 | 05:24 PM
brad8266's Avatar
LOL there was just a thread on this, but let me quicky explain it to you again.
YOUR CAR WILL NOT RUN RICH AT IDLE OR PARTIAL THROTTLE DRIVING AFTER A LONGTUBE INSTALL. I DONT CARE IF YOU THINK YOU SMELL FUEL AND IT IS RICH. 99.9% OF THE TIME THE FUEL SMELL IS BECAUSE WHEN YOU DO THE LT INSTALL YOU ARE ALSO INSTALLING AN ORY PIPE AT THE SAME TIME THUS ELIMENATING CATS. WHEN YOU DONT HAVE CATS YOU WILL SMELL FUEL, PERIOD. THE PCM WILL COMPENSATE FOR ANY FUELING CHANGES BY ADJUSTING THE LONG TERM FUEL TRIMS TO KEEP THE AFR CLOSE TO 14.7 AT ALL TIMES EXCEPT FOR WOT.
You people need to stop passing out misinformation around here. If you have no idea what you are talking about and are just spitting the same **** you heard from someone else here you should stop.
Old Oct 13, 2006 | 05:53 PM
burnzilla's Avatar
You lost power after putting on headers....
Old Oct 13, 2006 | 09:43 PM
1999 SS's Avatar
what do you suggest?
Old Oct 13, 2006 | 10:34 PM
brad8266's Avatar
I suggested that the thread poster first get rid of the MAFT he has. he should also do a scan whiel driving and watch for knock retard and monitor the LTFT's. if you dont have scnner then go to carputing.com and download the free LS1 Scan and use it, it works fine. It will take you an hour to download it to a laptop, connect to the car, and go log for a short drive. That will give you a good idea on whats going on with your engine.
Old Oct 14, 2006 | 05:45 PM
BuBbABFP's Avatar
hmm sounds like u may need a tune.. check for the header hitting on the K member.. may bee a false knock...?? good luck mang.
Old Oct 15, 2006 | 01:11 AM
BlackTAWS6's Avatar
I'm also experiencing some afterfire...
Old Oct 15, 2006 | 01:12 AM
brad8266's Avatar
As in exhaust backfire?
Old Oct 15, 2006 | 02:01 AM
DuronClocker's Avatar
You're a brave soul to be running a 100-shot on a car with an aftermarket MAF untuned.
Old Oct 15, 2006 | 02:35 AM
brad8266's Avatar
Or he is just ignorant as to what can result from that.
Old Oct 15, 2006 | 08:31 PM
BlackTAWS6's Avatar
yessir
Old Oct 15, 2006 | 08:39 PM
LSGunZ28's Avatar
I dont think the car runs at 14.7 :1
because usually at idle cars tend to run richer , especially at cold starting and at WOT run leaner. 14.7 is just the stoichiometric number for air/fuel ratio. but optimium air/fuel ratio is regularly in the ballpark of 13:1. of course depending on the car, engine, induction, etc.
Old Oct 15, 2006 | 09:27 PM
brad8266's Avatar
You cant be serious right? You must have no idea how the PCM operates. Once the car warms up and goes into closed loop it will try to stay at 14.7 unless you go WOT, then it goes strictly by what is in the MAF table. Do some research on what yolu are talking about before you spout out misinformation.
Old Oct 15, 2006 | 09:44 PM
LSGunZ28's Avatar
I do have an idea on how it operates. and I may not know as much as you maybe. But I have learned that 14.7:1 isnt really the A/f ratio cars generally operate at. That is just a ballpark number, just like how a 4 stroke cycle is: intake, compression, ignition, exhaust. But we all know it isnt that simple. a spark doesnt occur the whole time of the igntion cycle. just like overlap occurs and exhuast and intake cycle overlap with each other( just an example) and all those things. it isnt quite as simple. the A/f changes as TP changes as does load on the car, etc.
I am pretty certain of that.
But please put some input on my misinformation if you can, so that I can learn.
thanks.
