Top end power loss after headers
ALso, you saying that chrysler had lean burn cars means nothing...what does that mean? did they run 20:1 or what?
There are lots of SD Open Loop tune guys that do just that. They tune it to run realy lean at cruise while running around 14.7 under part throttle load and nice and rich at WOT. To accomplish this the LTFT's are disabled.
Crusing runs from the OLFA table, and then hitting the throttle goes into the PE table (-> but first VE table has been dialed in); also, never have to replace wornout/broken O2 or MAF sensors.
As you open up the throttle, you want it something like 13.0 or richer...
At peak torque you want 12.4 or so...
(the best AFR's will vary with each vehicle...)
running richer may also allow more advance without knocking.
But I'm sure you all know this already.
Log a few drives with a wideband (MAF-less and open-loop) and then correct the VE table; then adjust OLFA and PE tables for desired AFR values; wideband AFR will now match OLFA/PE very closely.
Edit: both HPTuners and EFILive software have the maps/tools to make this easy.
