Crankshaft Position Sensor Code
Old Oct 19, 2006 | 06:59 PM
gojo's Avatar
Default Crankshaft Position Sensor Code
P0336 Crankshaft Position Sensor A Circuit Range/Performance
I'm getting this code and the car runs like hell. It stumbles and finally stalls. I can then start it and all seems fine. But it always comes back.
The sensor has been replaced but it made no difference. Any help would be appreciated. It is frustrating.
Thanks
Joe
Old Oct 19, 2006 | 07:09 PM
2001NBMZ28's Avatar
Not sure, but think when you replace it you're supposed to do a crank sensor "relearn" with software. Try resetting the PCM and see what happens. Sorry not much help, someone will chime in...
Old Oct 19, 2006 | 07:29 PM
Z28_DAD's Avatar
yes you do have to do the relearn procedure. you pretty much have to take it to a shop with the right software. it may also be the reluctor ring on the crank.
Old Oct 19, 2006 | 07:48 PM
gojo's Avatar
We did a crank relearn and nothing changed. I'm hoping, bigtime, that it's not the reluctor wheel. The harness has been checked for continuity. Hoping that someone has seen some condition that seems unrelated but still throws the code.
Thanks
Joe
Old Oct 19, 2006 | 08:35 PM
Z28_DAD's Avatar
i had a GM truck that i put a motor in at work and the CKP had alot of metal shavings on it. i cleened it off and it ran great.
but id check the reluctor ring
Old Oct 23, 2006 | 06:53 PM
gojo's Avatar
It was 2 bad grounds.
It seems everything is ground problems with C5's.
Old May 11, 2007 | 02:33 PM
wm_sorg's Avatar
Where are the grounds? I have a similar problem. Also can the relearn procedure be done at home? If so what devide can do it?
