questions on spark plugs and wires.
This is what I run. LS2 wires are hella easy to pul off/put on. They are also a bit longer and allow you to angle the wire in such away that the boot will stay away from the header primary.
1. You dont need 10.4mm wires, your **** of statement to MSD is as stupid as a conversation of which car is faster and SS or Z28
2. Those Taylor wires are not better. I had two of them seprerate while changing plugs. That should never happen I'm not the only one who's had this happen to.
3. You did not gain power from switching good wires to good wires. You replaced your worn spark plugs.
Someone wants a quality wire at a reasonable price they use MSD superconductor wires. Someone wants to buy into advertising gimicks they go with thicker wires that fall apart.
I make a quality wire kit. I know how wires go together and what it takes to make them stay together.
The MSD has a boot that goes on the spark plug that you can bend to what ever direction you want it to go. Due to the double crimp electrode inside and design they are multi-angle. MSD is much much better. Taylor has a fat soft boot. I ran both wires side by side, I know wich one fared better. I will never use a Taylor wire again.
Conductivity is not improved just by making a wire thicker
It's the type of material used. All material has different conductive characteristics. Did you actualy measure loss to determine which one was better than the other?
someone wants a quality wire kit pm me.
I voted MSD and tr55's for the **** win. And I never use that stupid for the win line
I replaced them wih MSD wires. The boots on the msd wires are very good and stay away from the header primaries.
I used AC Delco iridium spark plugs but the NGK tr55 will work just as good.
As far as wires, OEM LS1 or LS2 or GMPP wires like I run are nice.
