Pacesetter y-pipe vs TSP y-pipe
yes its in about 4 pices but i find that if you get the 3in stainless exhaust banclamps from jes for like 10.99 each you will need 5 of them for the ssp pipe keeps the pipes nice and tight and exhaust leak free. fyi to help keep th pipe from banging when adjusting the pipe on the driver side wedge a 2x4 between the floor board and ypipe and then tighten the clamps and the n remove the 2x4 you should have no bnging issues
No experience with Pacesetter ypipe though.
Also, the TSP ORY bangs the floorboard when hammered from a dig.
The only thing I can think of is the knock sensor is hearing the noise and it is interpreting it as engine detonation, so it is retarding the timing. Is that right??
It attached to a bolt on the subframe on the driver's side. I installed it loosely on my Pacesetter ORY, then bolted it to the subframe. Once I had it bolted up, before I tightened it around the ORY I had a buddy take a long prybar and pry down on my ORY giving me max clearance between it and the floorpan. While he held it, I tightened the hell out of it. It's been there for almost two years and has NEVER banged the floor once. Ground clearance is still great as well, it doesn't hang low or anything. Personally I'd play around with the ORY a little bit before I put poly mounts in. I've heard nothing but tales of *** pain from those who've swapped mounts.
My only bitch about the Pacesetter piece is the crappy way the driver's side runs into the passenger side pipe. I had to take a Dremel with a flex shaft and hog it out. Look in there when you get it and you'll see. It was like they cut a small hole, then welded the pipe to it. For the money it's a decent piece though. TSP's looks like it may flow a little better. If I had to do it all over again, I'd get the Pacesetter ORY, as well as a Flowmaster merge and have it fabbed into the ORY instead of their half assed junction. The merge I'm talking about is a few items up from the hangar in the TR link.
Is the Pacesetter deal the best ground clearance ORY? I would think it would be because of the flat spot. Im not too worried about the bumping...i've got poly mounts and a bump stop (that should tell you about my experience with the TSP catted y).
Any pics of an installed pacesetter y?
