Ls6 Intake, What's The Advantage?
Old Nov 8, 2006 | 08:20 AM
PontiMANIac's Avatar
Default Ls6 Intake, What's The Advantage?
What is the advantage of upgrading to an LS6 intake manifold on a mostly stock 2000 LS1 with only a lid, ported TB, and Borla cat back upgrades?
I will probably never do a cam, head swap or headers so what gains can be expected by upgrading the intake and which one do you guys recommend?
I know a 90mm would be overkill.
Old Nov 8, 2006 | 08:27 AM
lastcall190's Avatar
You'd probably feel a little on the top end, bearing in mind the cam in the 98-00 is a little (little) bit bigger than the 01-02. Definitely can't hurt Go with the LS6 IMO
-J
Old Nov 8, 2006 | 08:28 AM
GregWS6&z28's Avatar
youre better off getting headers and not the intake. look around. used headers can be had for the price of the used or new intake.
Old Nov 8, 2006 | 08:32 AM
ApacheDrill's Avatar
more flow..with header like stated above, its a good mod
Ls1's are restricted.. more air in+more air out=more power
Old Nov 8, 2006 | 08:34 AM
I'm concerned about failing emissions which is why I mentioned I will probably stay away form the headers, cam and heads upgrades.
If I go with the LS6 intake will I lose any low end torque?
Old Nov 8, 2006 | 08:36 AM
What state do you live in? I'm not sure but I'd bet if anything's lost on the low end, it'd be negligable that you wouldn't feel
Old Nov 8, 2006 | 08:39 AM
I live in New Hampshire and the emissions test is a computer hook up to the OBD II, not a sniff test.
Old Nov 8, 2006 | 08:41 AM
Ah, well NJ has the same tests and I passed on my old LT1 with LTs and a catted Y-pipe... That was even the sniffer (moot point). We do the plug in test here, and I've known a few ppl that pass with ORY and having the rear 02s programmed out, it's just that you need to go through a drive cycle, just some food for thought Might as well do the intake now if you want, it's not like you have to do any of them in order, should you change your mind on headers down the road.
-J
Old Nov 8, 2006 | 08:47 AM
When you say a drive cycle you mean don't show up with a cold engine?
Old Nov 8, 2006 | 08:52 AM
I wish it was that easy... here you go:
http://www.obdii.com/drivecycle.html
My friend didn't do that, he just drove the car a lot when he put LTs and ORY on, and only failed because the CEL was on because of a busted AIR pump, his programming of the rear 02s was fine.
-J
Old Nov 8, 2006 | 09:03 AM
Holy crap dude, I just read the info you sent me and as much as I appreciate you really helping me out........It seems like more aggrevation than it's worth. I have a Diablo sport programmer that has the capability of deleting the EGR and AIR codes but I have been told that they only shut off the SES light and do not eliminate the signal to the OBD II.
Old Nov 8, 2006 | 09:22 AM
Tainted's Avatar
correct you are. you have to send in your pcm to a tuner to program out the rear 02's
Old Nov 8, 2006 | 09:52 AM
Please explain how having the PCM reprogrammed allows me to pass the OBD II test. Doesn't the test computer send up a red flag when there is no EGR reading or rear O2 sensor reading? Thanks.
Old Nov 8, 2006 | 09:56 AM
Tainted's Avatar
the pcm has codes and **** that make it trigger the lights. when you have it tuned, they take out those codes so nothing is triggered anymore
Old Nov 8, 2006 | 10:00 AM
And so my Diablo programmer only shuts off the light but does not take out the code?
Old Nov 8, 2006 | 10:02 AM
Tainted's Avatar
i dont know if it jsut gets ride of the lite or disables the codes period
Old Nov 8, 2006 | 10:08 AM
They claim in their ad that it is capable of "deleting" the p-codes. I think I'm going to delete the codes and then go for my inspection before I do the mods just to see what happens during the OBD II test. If I fail then all I have to do is reset the stock tune and then I will have my answer without first having spent a **** load of dough on up grades.
Old Nov 8, 2006 | 10:42 AM
Good call, I know that if you only delete the code, eventually it SHOULD come back. Case being, I had my friend delete my rear 02 code before I had them programmed out after headers... light went on no more than 50 miles later. Try to inspect first, then have two years to mess around with the car
-J
Old Nov 8, 2006 | 11:30 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Intake is worth it in my opinion. followed by headers. You get that thing breathing right and we are talking some good power for less money!
Old Nov 8, 2006 | 11:37 AM
99Transamls1's Avatar
About how many horses do you usually get out of an ls6 intake. 15?
