is there a write up on debaffling for the intake
Old Nov 8, 2006 | 02:28 PM
philly3384's Avatar
Default is there a write up on debaffling for the intake
? maybe its on this site or another i cant find nothing but i know a lot of people have done it.
Old Nov 8, 2006 | 02:33 PM
DirtyJohn's Avatar
Maybe soon there will be
If your planning it, your gonna want a dremel.
And I hope you like sanding.
Actually, there is one I remember seeing, it was short but it covered the basics.
If I remember right the thread title made it harder to find.
Old Nov 8, 2006 | 02:50 PM
firebird5134's Avatar
Debaffling the intake lid isnt that difficult. Its just a matter of getting out a pair of pliers and breaking off each of the baffles. And like dirtyjohn said I hope you like sanding
Old Nov 8, 2006 | 03:14 PM
Tainted's Avatar
you dont debaffle the lid
Theres a write up somewhere but be warned, you may wanna make some type of rain block-off plate
Old Nov 8, 2006 | 03:15 PM
DirtyJohn's Avatar
Oh I thought he meant the intake manifold.
If your doing the stock lid, I'd save the time and buy an aftermarket one.
Unless your trying to be stealthy and look stockish, in which case, I hope you like sanding.
Old Nov 8, 2006 | 03:19 PM
v8hunter's Avatar
Don't mess your time with modifying your stock lid as it will never flow as good as an aftermarket one. A new lid is only about $100 or get a used one for about half that.
Old Nov 8, 2006 | 08:58 PM
gnomee's Avatar
Unless you are trying to go stealth like they mentioned above. Buying an aftermarket lid is much more worth it. Unless your time is worth less than $20.00 an hour or so. Then you might want to do it yourself.
The aftermarket lid is shaped differently and it also gets rid of the stock resonator.
Old Nov 9, 2006 | 08:03 AM
philly3384's Avatar
Default thanks
which lid should i go with? i was thinking slp
Old Nov 9, 2006 | 08:43 AM
DirtyJohn's Avatar
There mostly all the same, and all run around $100.
What to look for is a connection for the AIR hoze, if you care.
If your year is < 01' you'll need to buy a breather that goes on the end of the hoze for $5 or so and tuck it away in your engine bay, which I think looks kindof janky, so I nuked my AIR with the LT's.
Basically, look for what you think looks the best, carbon fiber, clear, logos etc...there pretty much all the same.
I have an MTI if it matters, and ive been pretty rough with it and its held up like a champ.
Old Nov 9, 2006 | 08:44 AM
GregWS6&z28's Avatar
thats a good choice. GMHTP did another lid article recently and you may be able to find results online. You really cant go wrong with any of them, and you can find most for $100 new. SLP/TSP etc
Old Nov 9, 2006 | 09:20 AM
300bhp/ton's Avatar
A lids a lid. All the same HP.
If you search however there appears to be more issues with MTI & Whipser lids cracking.
SLP seem pretty decent although some, and it is only some complain of it rubbing the inside of the hood.
TSP (Texas Speed & Performance), when I was researching this, TSP lids seemed to have the least amount of negative comments.
But as they are all ~$95 it doesn't really matter.
And yeah don't waste your time with the stock lid. The baffles are not the issues with it, it's the plenium size and the 2 great big air silencer attached to the lid that affect the performance.
