TD question
Old Nov 8, 2006 | 03:41 PM
GreenBlood's Avatar
Default TD question
Is there any way to get TDs to pass emissions? Where I live its just the obdII test...This would be for an LS1 BTW..thanks...
Old Nov 8, 2006 | 03:44 PM
Zymosis's Avatar
As long as they don't do a sniffer test and you aren't throwing any codes I think you will be fine
Old Nov 8, 2006 | 03:48 PM
71camaro's Avatar
If you get your car tuned and they delete the code for the emitions then you will be just fine.
Old Nov 8, 2006 | 03:59 PM
GreenBlood's Avatar
is there any way to tell u deleted the code?
Old Nov 8, 2006 | 04:01 PM
Zymosis's Avatar
Is there a Service Engine soon light illuminated?
Old Nov 8, 2006 | 04:10 PM
GreenBlood's Avatar
when i get my 8-02 LS1 this summer, the first thing I am doing is lid, and then pacesetter longtubes, and I think I am going to go with their true dual kit with sweet thunders if I can make it pass emissions...I am probably going to be installing these myself with a buddy of mine, so do I jusr bring it to a performance shop to tune it so that it doesn't throw codes?
Old Nov 8, 2006 | 04:11 PM
GreenBlood's Avatar
do you have a guess as to how much that would cost?
Old Nov 8, 2006 | 06:31 PM
GreenBlood's Avatar
anyone?
 Michael S. Palmer
Old Nov 8, 2006 | 06:44 PM
CockerKid009's Avatar
you mean the tuning or the LT's w/ TD's? check texasspeed, they have sweet deals on pacesetters with a TD setup that dumps before the axle, i think 375 for the headers and somethin like 400 for the duals. As far as tuning, if all you did was get the code deleted it shouldnt be too bad, don't know though-this is just information i gathered from on here. You could also check into getting a mail order tune to delete the code and also tune your car for the LTs
Old Nov 8, 2006 | 07:27 PM
Cld069's Avatar
Call some shops around your area to make sure that they will be able to tune your car and see what programs they will use ie. HP tuners, LS1 edit, etc. If they are able to tune your car, then they will be able to delete any codes thrown as well as dial in your a/f ratio. Cost could be anywhere from $300-600, just depends on the shop. Your much better going with a HP or LS1 Edit tune than a mail order tune imo but if the budget gets up there I can understand.
Old Nov 8, 2006 | 09:55 PM
GreenBlood's Avatar
how much is LS1edit, i couldn't find the price online...if i go this route, is it straightforward? will i know if i deleted the code? If all else fails, I'll call the Speed Inc and Area One Motorsports and see how much they charge...thanks...
Old Nov 8, 2006 | 11:38 PM
GreenBlood's Avatar
ttt...
Old Nov 9, 2006 | 01:21 AM
loyolacub68's Avatar
ls1edit is probably gonna cost you in the neighborhood of 500 bucks
Old Nov 9, 2006 | 09:36 AM
GreenBlood's Avatar
thanks
Old Nov 9, 2006 | 09:58 AM
GreenBlood's Avatar
HP or predator tuner? or LS1 edit over both?
Old Nov 9, 2006 | 10:04 AM
GreenBlood's Avatar
SLP also has a Diablosport tuner? I saw it on lmperformance.com it $80 more than a regular diablosport...Is it worth the extra $$? when I do the exhaust install, I'll probably just save for the tuner because I doubt I'll have to emissions as soon as I buy the car...
Old Nov 9, 2006 | 10:57 AM
300bhp/ton's Avatar
WTF?
Why will duals affect emissions anymore than a catback?
As long as you are running cats it won't make any odds.
Old Nov 9, 2006 | 10:59 AM
300bhp/ton's Avatar
Well according to your sig you have an ORY so technically will fail a sniffer test anyhow. Plus a visual. If the PCM is throwing codes for the lack of CATS (or EGR/AIR) then you'll fail ODBII as well.
Duals will have ZERO affect compared to running a cataback. The things that make you fail are all listed above and can all be run with duals if you so want.
I guess some places won't like the exhaust dumping under the car, but running them out the back solves that problem.
Old Nov 9, 2006 | 01:20 PM
GreenBlood's Avatar
its not for the car in my sig, that car is sold...
Old Nov 9, 2006 | 01:21 PM
GreenBlood's Avatar
ttt. for the tuner question...
