Muffler Suggestions and Location.
I've got a borlamouth setup at the moment. The borla however is too big and the driveshaft has made my muffler its bitch. And ground clearance has become a distant memory. (As if the cutouts arent low enough.)
So here's what I want to do. I want to get rid of the borla muffler and weld in a new muffler or mufflers. I was thinkin the stock location, but that would require a specific muffler. Whereas I really like the sound of the gmmg, dynomax bullets, and Classic Chambered Powersticks. I was thinking of possibly welding in mufflers right before the tips?
Here are the details, I have qtp lt's, a frankenstien mufflex ORY (no cats), and a borlamouth.
I'm on a tight budget, so the dynomax bullets are enticing. I like it loud, and I like it low. Old school muscle style. Any suggestions? Can the mufflers be welded before the tips? Anyone have any similar set ups? Help me out!
Brandon, I've gotta have tips on the back of the bird, and im trying not to make it so that I need any custom exhaust built.
If you want cheap then I'd look at Classic Chambered Exhaust Powersticks, they are only aluminiumised steel, but should last ok.
Run one long lenght down the I pipe. Probably as long as will fit there. And remove the Borla.
This will probably be quite loud still. If you want to add more muffling for db reduction or tonal quality you could then add a short muffler before each tip.
Again I'd look at the Powerstick muffler as they can be had in various lengths. Or a Flowmaster 10 Series would also probably fit.
Or just run the Flows before the tips and not bother with the I pipe muffler.
Take a look at the Stainless Works Chambered exhaust, it should give you an idea of how the locate the mufflers.
I really want to make sure the tone is nice and deep, because i'd like to go H/C in the future. And maybe even an iron block and other goodies. It's a trans am. I want it to sound like one!
