Is Ls6 possibly better than Fast 90/90
Old 11-19-2006, 01:50 AM
Justin00SS's Avatar
Originally Posted by Cop Car
i too have seen several people who are less than satisfied and are going back to LS6 intakes. IMO, LS6 is fine... untill you need a single plane carbed intake or a sheet metal. go big or go home
Says the guy whos car is bone stock with sd tune.
Old 11-19-2006, 05:52 AM
300bhp/ton's Avatar
You should see some of there other advice, such as TB porting equals zero HP, this was directed at Bo White
Or the fact they also claim the MS4 cam is junk, which they knew all along, even though several people have seen over 480rwhp with the correct heads.
Old 11-19-2006, 04:09 PM
Cop Car's Avatar
you are both jackasses. its been dyno proven that a TB = less than 5rwhp. essentaly 0. you get more hp by taking your A/C belt off, or deleting your power steering.
MS4 is over rated junk. its not much bigger than the MS3 and LG motorsports makes much better cams. i dont see the MS4 up on the top cam only lists. i do however see a x4. and thats not even the biggest cam LG makes. put the MS4 up against the G5xX.
if i wanted an englishmans opinion id go to the gay bar.
Old 11-19-2006, 05:34 PM
mullenh's Avatar
Talking
cat fight!!!!!!!!!!!!!
Old 11-19-2006, 06:21 PM
SiL3NtXWS6's Avatar
Fast 90/90 is most definitely worth it. Excellent throttle response and picked up power all over the powerband.
It ain't big enough though
Old 11-25-2006, 06:29 PM
Bo White's Avatar
I like you....you stand behind your beliefs and dont sway from them
BTW, what dyno do you want me to meet ya at
Old 11-25-2006, 09:09 PM
Justin00SS's Avatar
says the guy with a bone stock car w/ sd tune. lol
What's the point of tuning a car to SD (deleting the maf) if there wasn't a gain from it.
So if there is a gain from deleting the maf (a restriction) then why are you adamantly against porting a tb? Your tb is already there allowing enough airflow to make the power you already make. Porting is only making it more efficient.
Old 11-25-2006, 10:27 PM
ULTIMATEORANGESS's Avatar
ill be adding these soon. i have H/C.
Old 11-25-2006, 10:42 PM
Andros's Avatar
I have a si LS1 w/ a fast 90
Old 11-25-2006, 10:44 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
This thread is nearing it's bitter end. Don't start up the turmoil talk and name calling.
