putting '02 headers on a '00
Old 11-26-2006, 01:32 PM
SUCK MY SS's Avatar
Default putting '02 headers on a '00
this guy is gonna sell me his headers, but they are off of an 02 non race style? what would i need to do to run them on a 00? i believe mine has AIR and his is EGR...i will be removing my smog equipment so will i need to make some sort of block off plate?
Old 11-26-2006, 01:46 PM
bww3588's Avatar
yours has AIR and EGR. his only has AIR. if you are going to remove your AIR and EGR, they will work. just make block off plates for your AIR and EGR bosses.
Old 11-26-2006, 01:56 PM
Moderator
davered00ss's Avatar
Run a block off plate for the Air tubes and delete your EGR & Air.
Old 11-26-2006, 02:07 PM
SUCK MY SS's Avatar
sounds simple enough....might just weld em shut
Old 11-26-2006, 05:46 PM
Coy
Coy's Avatar
Also you can buy AIR tubes for a 2002. If you actuallt want to keep it.
Old 11-26-2006, 05:58 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
f-that!
Old 11-26-2006, 06:01 PM
2xLS1's Avatar
00 and 02 AIR tubes are the same.
Old 11-26-2006, 06:04 PM
SUCK MY SS's Avatar
ima remove all the smog stuff anyways so its cool...worst case scenario i just put em back when i need to resmog it
Old 11-26-2006, 06:05 PM
Coy
Coy's Avatar
I was told they have different part numbers. Oh well.
