Cuts outs single vs. double?
Old Nov 27, 2006 | 01:30 PM
1FSTLS1's Avatar
Default Cuts outs single vs. double?
What is the sound difference between having cutouts (one on each side) on the headers vs having just one at the y-pipe where it meets the cat back system? Obviously 1 is cheaper than buying two. Any one have experience with this also any picts of a set up with the SLP long tubes as my ground clearance is already an issue? Any advice would be appreciated.
Old Nov 27, 2006 | 01:48 PM
pSSycotic's Avatar
Just do the single in the I pipe. When i got Pacesetter LTs it came with a Y pipe that had dual cut outs. sounds bad when opened and they scrape EVERYTHING in a lowered car. Im about to sell mine and get a regular Y pipe
Old Nov 27, 2006 | 02:17 PM
1FSTLS1's Avatar
My car is not lowered just that the SLP long tube headers hang real low. Are you cut outs electronic if so how much?
Old Nov 27, 2006 | 03:29 PM
transAm-98's Avatar
I used to think the same thing when I had dual cut outs. But After a lot of work I got the Y pipe tucked up to where it wasn't a huge issue (I'm also lowered 2"). But the sound wasn't the great. Then I got a cam and found a whole new appreciation for my cut outs. Not to mention a huge gain in power with them open.
Old Nov 27, 2006 | 03:57 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
..cutouts on each pipe is VERY LOUD...1 in I-Pipe is not bad..I think 2 sound better..alot better....Go to QUICK TIME PERFORMANCE.../...QTP.....Sponsor on right....>>>>>>>>
