FAST Intake Issue
Old Nov 30, 2006 | 11:56 AM
Raven02TA's Avatar
Default FAST Intake Issue
having a fitment issue with the fast 78MM intake i just bought from a friend.
if i put the intake on it looks as if there is still a gap between the head and the intake. (without it bolted)
Has anyone used this intake with the LS6 Valley cover? it seems that my intake is really close to the port at the front. also i am using hax head bolts from ARP for the knock sensor (valley) cover and im wondering if the bolts are too tall. if i remember right the stock bolts are rounded head?
or could i just be retarted because i dont remember if i removed the clip that holds the knock sensor wires down.
Old Nov 30, 2006 | 12:07 PM
ShevrolayZ28's Avatar
I think the valley cover bolts are getting in the way.
Old Nov 30, 2006 | 12:08 PM
chuckyt1's Avatar
Mine came with "low profile" bolts for the valley cover
Old Nov 30, 2006 | 12:19 PM
Raven02TA's Avatar
hmmm it seems i will need to order me up some bolts. its consistant all the way to the back of the intake. so it seems ill have to order up some low profile bolts.
Old Nov 30, 2006 | 12:33 PM
Try positioning the intake with the valley bolts removed, this will confirm the situation.
If the bolts are the culprit and if you're in a hurry and you're good with a grinder, you might be able to grind'em down, but be very careful that you don't grind your fingers. Use plyers, or better yet, thread the bolts into something and carefuly grind.
Old Nov 30, 2006 | 12:45 PM
TheBlurLS1's Avatar
That's what she said...
The new bolts are button head allens.
Old Nov 30, 2006 | 12:46 PM
Raven02TA's Avatar
yea im not in a hurry so i can wait for them to come in. i onyl drive the car a few times a month.
Old Nov 30, 2006 | 12:56 PM
Raven02TA's Avatar
here are the pics from this morning i took.
Old Nov 30, 2006 | 01:02 PM
ROCNDAV's Avatar
My FAST 90 fit over my LS6 valley oer with no problems. Both my FAST 90 and my LS6 valley cover came with new bolts (valley cover had low profile, rounded hex head screws, fast had Button head cap screws), I forget which ones I used.
Old Nov 30, 2006 | 01:03 PM
Raven02TA's Avatar
yea the general concensous says its the bolts which i will have to buy and install.
ROCNDAV's Avatar
Yeah, those are some talls screws on your valley cover. Did you use new intake gaskets or reuse your old?
Old Nov 30, 2006 | 01:25 PM
Cheatin' Chad's Avatar
You'll definitely need to change out your fasteners.
Old Nov 30, 2006 | 01:34 PM
Raven02TA's Avatar
they are the old ones that came off my friends car. they are still in great/clean condition so im not going to worry about them
