truck 85mm sensor
If you are still intent on doing it, look to the right at our sponsor list. Casper's electronics is one of them (at least they used to be)...they sell the harness to adapt the 3 wire connector (stock) to the 5-wire 85mm. The 85mm MAF incorporates the inlet air temp sensor in the MAF housing itself (that's where the other two wires come from).
The actual unit itself has to be calibrated. I'm talking about the MAF sensor, not the PCM computer in the car, which has to be calibrated also...
But the unit has to be calibrated, otherwise the voltages will not be read correctly, they won't line up. The only place I know of that sells a calibrated MAF unit is PaceParts, which is why you don't read of anyone having problems if they buy their 85mm piece from there.
Don't buy into the marketing...the calibration lies solely in the PCM.
A Vettes 85 MAF sensor puts out voltages through a higher range than a ls1 MAFs. As an arbitrary example (I don't remember the actual numbers) a Vette MAF will go from 0v to 16v, whereas a ls1 sensor will only go from 0v to 13v...
If you just put a Vette MAF sensor on an ls1 it will NOT be calibrated. Regardless of what you do in the PCM...the unit itself will only send out certain voltages. THAT's what the calibration does, modify the MAF itself to send out the correct voltage range.
When we were tuning my car for the 85mm sensor, we noticed it put out voltages that were correct for ls1...compared to the PCM table they were spot on, compared to the voltages that are hard-coded into the PCM. We tested this by downloading a Z06 PCM file and reading the MAF voltages in the tune, and they had a range that was higher than the ls1 went to. So a Z06's PCM file expects voltage ranges that are outside the range of an ls1 MAF sensor, as they are hard-coded into the PCM file to read a specific range.
Therefore, without calibration, it's pointless to run a 85 mm MAF on a ls1 car, because it won't be reading the correct voltages from the MAF unit itself.
Also, that's what SLP tries to do with their "resistor" mod...it tricks the MAF unit to put out a different voltage range than normal, simple electronics using a resistor, technically should work just as good, but in reality DOESN'T work just as good as the calibrated unit from PACE.
https://ls1tech.com/forums/pcm-diagnostics-tuning/620036-trying-find-info-voltage-differences-z06-85mm-maf-sensor.html
Maybe that's why I don't like 85mm MAF sensors. Too much thought required
That may actually get the calibration close to the stock MAF, but it just seems to me that some frequency ranges may need more adjustment than others to match the stock MAF (the 85mm MAF may be further off from the stock MAF in the lower frequncy range, say 8% then may only measure 5% different in the upper frequencies, for example) the resistor is going to adjust the MAF's entire out range up or down an equal amount.
