best way to remove rasp
Poly motor mounts help and/or eliminate most of it. I've experienced it even after installing the mounts when my muffler/exit pipe on the driver's side was just about to fall off the hanger. The result of it being less secure was more play and movement and I heard more rasp. Just my observation.
also, a lot of the rasp is caused by the LS1 itself. the LS1 has a wacky firing order. the LS1's firing order is, i believe, 1-8-7-2-6-5-4-3. the order that the cylinder's fire in causes rasp. going to true duals will only take into account 4 cylinders per each pipe instead of all 8 cylinders going into 1 single pipe. since only 4 cylinders are being taken into account, that will cut down on some of the rasp, also.
true duals aren't perfect. sweet thunders are kinda raspy IMO, but true duals in general are the best chance you'll get at limiting rasp on the LS1. it may not be gone 100%, but it's certainly less raspy than anything a y-pipe setup can get you.
wow, i did not write that so well
Thats awsome man. Now there is a great excuse for me to get a true dual system.. That and the ( my exhuast is hanging waaay too low and Im scraping issue, should be enough for me)
But why doesnt the LT1 sound raspy, even though it has the same Y pipe setup.. It cant only be the firing order difference.
You didn't hear what you wanted to and throw a hissy fit? **** YOU are you nine?
The only person crying is you, wanta talk race cars? I had a BBF T-bird before my 2nd nut dropped. You are the ******* ricer ***** that give LS1s a bad name.
So many times you can't even back you reasoning and still stick too it like your ******* Moses himself holding all 10 damned commandants. You are a tool who can't pioneer **** and rides the bandwagon of fat misinformantion on this site.
Wanta "own" choco and post how balla and right you are? How about this mr I own a race car? Dnyo your car with cats then with out show this 54908645908605 HP differnce you seem to claim.
No Child left behind has failed you are the poster child for it.
you dam douche bag who the hell are you calling me a ricer, I dont gave a **** if you have a funny car Im not a dam ricer I tear ricers apart and suck ther pait off and those ugly *** body kits. If yoy read the thread I havent said one dam word about any hp difference you tool bag I just said I dont mine the rasp. You dam right I own a race car and my ls1 IS NO ******* RACER LS1 IS "BUILT BY GOD" I'd rather buy cats just to beat the hell out of you with them, No child left behind is a ******* mistake and joke just like you douche bag.
firing order plays one of the biggest roles in sound of all, my man. ever wonder why a ferrari and a lambo sound so high pitched, even with a V8 or big V12? it's because their cylinders fire in order. they fire 1-2-3-4-5-6-7-8 or 1-2-3-4-5-6-7-8-9-10-11-12. firing order plays one of the biggest roles of all in sound. why do you think mustangs sound so alike?
Lol, they( Ferrai and Lamborghini) dont fire in that order!!!
Im not sure the block material has to do with the sound so much...
The firing order maybe...
The Y pipe is believeable as well.
But the firing order you gave for the v12 is ridiculous
Lol and rip the crank in half.
i'm trying to picture this.
say these are the cylinders:
7 8
5 6
3 4
1 2
now here's how they fire:
4 6
2 8
3 5
1 7
i think. i think.
that's more like how a ferrari would fire. something along those line.
ferrari's use a flat crank V8. nothing's gonna rip off.
7 8
5 6
3 4
1 2
4 6
2 8
3 5
1 7
i think. i think.
dude before you go on any further... are you sure, you know what you are saying?
if this was an inline 4
1-2-3-4
and it fired
1-2-3-4
the crank would twist in half.
wtf is a flat crank? wtf?!?!?!
1-2-3-4
and it fired
1-2-3-4
* The cross-plane V8 is the typical V8 configuration used in American road cars. Each crank pin (of four) is at a 90° angle from the previous, so that viewed from the end the crankshaft forms a cross. The cross-plane can achieve very good balance but requires heavy counterweights on the crankshaft. This makes the cross-plane V8 a slow-revving engine that cannot speed up or slow down very quickly compared to other designs, because of the greater rotating mass. While the firing of the cross-plane V8 is regular overall, the firing of each bank is LRLLRLRR; this leads to the need to connect exhaust pipes between the two banks to design an optimal exhaust system. This complex and encumbering exhaust system has been a major problem for single-seater racing car designers.
* The flat-plane V8 design has crank pins at 180°. They are imperfectly balanced and thus produce vibrations unless balance shafts are used, with a counter rotating pair flanking the crankshaft to counter 2nd order vibration transverse to the crankshaft centerline. As it does not require counterweights, the crankshaft has less mass and thus inertia, allowing higher rpm and quicker acceleration. The design was popularized in modern racing with the Coventry Climax 1.5 L V8 which evolved from a cross-plane to a flat-plane configuration. Flat-plane V8s on road cars come from Ferrari (the Dino), Lotus (the Esprit V8), and TVR (the Speed Eight). This design is popular in racing engines, the most famous example being the Cosworth DFV.
11 12
9 10
7 8
5 6
3 4
1 2
so that means the cylinders would fire in this order:
4 8
6 12
2 10
5 7
3 11
1 9
notice how the whole left side of the engine fires before the whole right side of the engine? that is this "straight firing order" i'm speaking of. the whole left side fires before even one cylinder on the right side. this is what makes a ferrari sound like a mean V6
http://en.wikipedia.org/wiki/Firing_order
