bbk 80mm throttle body
Old Dec 12, 2006 | 03:18 PM
bigpappasz28's Avatar
Default bbk 80mm throttle body
where can i get the gasket set for the throttle body i think it flat type on the other side is the o ring type wich is on the intake but i need the one that goes in between the throttle body and spacer
Old Dec 12, 2006 | 03:52 PM
anyone need help idle to high due to bad gasket
Old Dec 12, 2006 | 04:24 PM
2001whiteSS6spd's Avatar
http://store.summitracing.com/partde...5&autoview=sku
Old Dec 12, 2006 | 05:36 PM
thanks for youre help
Old Dec 15, 2006 | 12:15 AM
whs's Avatar
whs
What do you mean, there is supposed to be a gasket for the BBK Throttlebody?
I bolted mine up to the LS6 intake, used some sockethead cap screws as the original ones wouldn't fit. Everything went back together after trimming the bellow a bit. Car runs fine, excluding a minor coolant leak (either I didn't get the coolant lines on it properly or I damaged one of the pipes on the throttlebody).
Old Dec 15, 2006 | 06:04 PM
JPH's Avatar
JPH
i got an extra one, oh and does your throttle stick, the one i have worked on had issues sticking.
Old Dec 15, 2006 | 07:32 PM
to whs it does have a gasket between the throttle body and black spacer
yep it does stick but just thread in the set screw a little more and that will help it
Old Dec 17, 2006 | 06:21 PM
whs's Avatar
whs
So yours had a gasket and a spacer, interesting. I bought mine used and it didn't come with either. After I found the right screws it bolted up just fine and the car runs okay.
Did yours come with different bolts?
Old Dec 17, 2006 | 09:40 PM
i think then you have smaller than 80 mm because i tried to put in on with out the spacer and the blade hits the intake it will not clear the opening due to larger throtle plate
Old Dec 19, 2006 | 04:51 PM
whs's Avatar
whs
No, I have the 80mm BBK Throttlebody and it is bolted directly onto an LS6 intake manifold without a spacer. The throttleblade and opening are noticeably larger.
